Author Topic: Cold weather storage  (Read 9426 times)
Offline nihsif
  • Unit(s): 898c si
« on: January 14, 2013, 08:40:12 AM »
I have a detached, uninsulated garage and am in north country, temps below zero are possible.
I store my electronics in the garage... is that proper? Should I store in a heated room in the house?
Re: Cold weather storage
« Reply #1 on: January 14, 2013, 09:24:55 AM »
Electronics are warm weather pieces of equipment unless it has been specifically made for extreme cold.
With computer and sonars I would suggest storing in a place above freezing.
Caution is the best suggestion as opposed to hurting your unit.
Offline nihsif
  • Unit(s): 898c si
« Reply #2 on: January 14, 2013, 09:35:04 AM »
Thanks for the quick reply... I haven't had a problem yet ... that I know of... will store in the house!
« Reply #3 on: January 14, 2013, 09:42:40 AM »
That would be the safest thing to do.  Hope the connect and disconnect is not too much work.  But will probably be the best in the long run..
Offline short grub
  • Unit(s): 1198 SI combo, 1159 DI combo
  • Software: latest
  • Accessories: terrova 80lb w/I*lLink 360transmt
« Reply #4 on: January 17, 2013, 09:20:31 AM »
 I have stored four units, two HB and two lowrance/eagle locators in my garage for 14 years every winter and get temps here as low as 10 or 12 below a few times, I live in central illinois so we do see the cold some years
all with never a problem
« Reply #5 on: January 17, 2013, 09:37:00 AM »
I think that humidity/moisture would be a
bigger threat to the units, rather than cold
temperatures.
If they are kept in a dry building/shed, then
they would probably be Ok.
Leaving them outside, uncovered would be
about the worst thing for them.
« Last Edit: January 17, 2013, 09:38:33 AM by ITGEEK »
« Reply #6 on: January 17, 2013, 12:03:06 PM »
If you have any doubt then take the safe approach. Dont risk your unit as repair can be quite expensive.
As several have pointed out there are related influences that could harm your unit.  If very cold is the norm then I would suggest keeping it warm..
chuck
Last post July 11, 2012, 02:29:26 PM
by Gattlin
Last post October 13, 2012, 09:39:03 AM
by Rickard
Last post August 25, 2013, 02:23:12 PM
by LittleGazoo
Last post December 26, 2013, 02:10:14 PM
Last post January 06, 2014, 10:46:20 PM
by Gattlin
Last post April 13, 2014, 11:01:47 AM
by Goosedwnr
Last post May 30, 2015, 07:18:17 AM
by Wallin8r
Last post June 07, 2018, 06:07:21 AM
by tailortom
