Author Topic: My first SI unit  (Read 20322 times)
Offline dkozyra15
  • David Kozyra
  • Unit(s): 898c HD SI
My first SI unit
« on: July 28, 2013, 10:31:28 AM »
Hey everyone new to the forum and new to SI spent a bunch of time reading about installs and other useful tips for using the 898 to its maximum potential. I'll basically be using mine to fish for trophy fish! My last unit was a Humminbird dual ducer wide beam so the bracket to hold the transducer was the same I just swapped them out. Gonna give it a test run to see how it will work from there if the motor blocks it there then my only other option is to move it under the boat i think with one of those stem mounts let me know what you think constructive criticism is always welcome because I sure want to get the most of her! Heres a few photos.
Follow me on instagram & twitter @ dkozyra15 for more monster fish photos!
Re: My first SI unit
« Reply #1 on: July 29, 2013, 01:20:48 PM »
Welcome to the Humminbird Side Imaging Forums David.
It looks to me like you have the angle of the HDSi transducer wrong.  It should be parallel to the surface of the water when you boat is underway.  It look way too low in the back.
Does your motor have hydraulic tilt/trim capabilities?
Offline dkozyra15
  • David Kozyra
« Reply #2 on: July 29, 2013, 01:47:57 PM »
I'm not sure what I can do about the angle because the transom runs at an angle like that. And as far as height I went off of what they instructed and that was 1/4" below the transom it doesn't say whether that 1/4" is from the end or the front of the ducer. And yes I do have hydraulic trim on my boat. I'm gonna test it out tonight hopefully and see if it works or not I'm thinking I might need the stem mount transducer for it instead and put it underneath.
« Reply #3 on: July 29, 2013, 01:54:54 PM »
David,
Where the transducer is bolted to the Pivot arm is where the transducer can be adjusted to change its running angle.  Loosen these two bolts up enough to move the transducer and then tighten them back up.
Offline dkozyra15
  • David Kozyra
« Reply #4 on: July 29, 2013, 02:00:33 PM »
Thanks for the info I'll be playing with her tonight so ill try that!
Offline Patty
  • Unit(s): 898c SI
  • Software: 6.4??
« Reply #5 on: July 30, 2013, 09:53:56 PM »
Good to see you made it over here!!!
Offline dkozyra15
  • David Kozyra
« Reply #6 on: July 30, 2013, 11:04:20 PM »
Well never got her in the water today but got the power and everything all hooked made a slight adjustment to the ducer and tomorrow night will give her the water test will report with final pictures of install. Thanks for the advice to come here Patty lots of good info on here!
Offline lcookie
  • Unit(s): 998SI/1198SI/788DI/587DI
  • Software: 6.68/6.64/6.64/6.09
  • Accessories: Ethernet, GRHA, ASGPSHS,WeatherSense
« Reply #7 on: July 31, 2013, 01:09:32 AM »
I always get worried about ducer in front of bunk board like that.  If you miss on your line up could rip it off boat.
Offline V Side Down
  • Unit(s): 898c SI
  • Software: 6.460 ?
« Reply #8 on: August 02, 2013, 12:59:55 PM »
The transducer should pop up if the bunk is hit.
Offline dkozyra15
  • David Kozyra
« Reply #9 on: August 02, 2013, 01:44:39 PM »
Tested her out yesterday and all was well no interference no motor in the way will post pictures later
Last post May 24, 2012, 04:42:15 PM
Last post April 13, 2014, 11:01:47 AM
by Goosedwnr
Last post September 22, 2015, 12:38:09 PM
by Sonartech
Last post October 25, 2014, 04:06:06 PM
by D S
Last post August 25, 2014, 12:35:36 PM
Last post January 15, 2015, 04:21:23 PM
by bigkahuna
Last post April 15, 2016, 10:37:41 PM
