Author Topic: one unit two locations  (Read 8864 times)
Offline anvil
« on: July 19, 2014, 11:39:52 AM »
planning on buying a 999 si. want to be able to use it on the bridge or down below depending on the weather. Know I will need 2 power cables. Is there a trasducer cable splitter that I can go to both locations?
thanks Roy
Re: one unit two locations
« Reply #1 on: July 19, 2014, 11:57:13 AM »
The US3 switch allows 2 head units (or 2 unit stations)...to be hooked to 1 xducer...
http://www.humminbird.com/Products/US3/
You will probably want a second gimbal bracket also...
http://www.humminbird.com/Products/GM-2/
And you may want a second cable collector...(I could not find this on the HB website)...
« Last Edit: July 22, 2014, 01:56:26 AM by rnvinc »
« Reply #2 on: July 21, 2014, 11:44:18 AM »
Make sure that is the correct Connector Collector when you order it Roy.  It needs to be Humminbird part# 540232-1 for the "HD" 800 and 900 series units.  You may have to get this direct from Humminbird.
« Reply #3 on: July 22, 2014, 02:08:21 AM »
I removed my link to the Collector cable at Amazon because it was the wrong one and I didn't want Anvil buying the wrong one...
Thanks Greg...for inputting the correct part number of the cable collector...
« Last Edit: July 22, 2014, 02:09:35 AM by rnvinc »
Offline Sonartech
  • Unit(s): 987, 997,1197, 1198, Onix 8
  • Software: Latest within days
  • Accessories: weathersense, IpilotLink
« Reply #4 on: September 22, 2015, 12:38:09 PM »
Just an update on the collector for the internal GPS 800 and 900 units. It is now available as an accessory under part #MBCC-900Ci (740144-1)   http://www.humminbird.com/Products/MBCC-900ci/
Use
Last post September 16, 2011, 07:00:25 PM
by SonarTRX
Last post November 13, 2012, 10:49:59 AM
Last post April 30, 2013, 05:46:41 PM
by Rotus623
Last post May 22, 2013, 12:00:36 PM
by Rotus623
Last post August 02, 2013, 01:44:39 PM
by dkozyra15
Last post April 30, 2014, 05:54:53 PM
by Tr-196
