Author Topic: Question about a Humminbird 987c  (Read 7093 times)
Offline Earl Marshall
  • Unit(s): Humminbird 987c
« on: May 27, 2013, 03:54:13 PM »
I was on the lake today and my humminbird 987c shut down and it tried to start back up by itself but it froze up. I had to unplug it to get it to turn off from where it froze up. Can anyone please tell me what I can do to fix it?
Re: Question about a Humminbird 987c
« Reply #1 on: May 28, 2013, 11:39:14 AM »
I would start by getting the battery it is powered from load tested to make sure it is still good.  We’ve seen this on other things caused by lower power issues.  The voltage may look right but there is not enough current flow to keep the 987 unit running correctly.  I would next try checking all of the electrical connections between the unit and the battery.  No loose or corroded connections – even in the fuse holder and the fuse.  If you have not done so in the past you may want to run a new set of 14 AWG multi-stranded copper wires from the unit to the battery (with a new 3-amp blade type in-line fuse).  Solder and seal all connections.
Last post September 14, 2009, 06:22:16 PM
Last post May 30, 2011, 01:56:35 PM
by stillbear
Last post August 16, 2011, 06:02:43 PM
by 6speedy3
Last post July 25, 2013, 12:41:16 PM
by diver651
Last post March 07, 2013, 08:35:55 AM
Last post March 16, 2014, 04:51:43 PM
Last post April 10, 2015, 02:22:20 PM
Last post December 17, 2015, 09:01:36 AM
by JoeyWelch
