Author Topic: Humminbird 1198 question  (Read 10752 times)
Offline Sigler
  • Unit(s): 1198c 788ci di
  • Accessories: interlink
« on: February 18, 2011, 11:59:22 AM »
Can someone tell me what that is happening on the left? Shouldnt that be mainly black?
Re: Humminbird 1198 question
« Reply #1 on: February 18, 2011, 01:47:40 PM »
Hard to tell from the low-res picture but it looks like you are getting most of the left Si sonar blocked by something.  Try trimming up your motor as high as you can and see if that helps.
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #2 on: May 30, 2011, 01:56:35 PM »
Yes that is reflection from the bottom of your motor bracket or your Jack plate which ever one
you have. take a piece of metal fill in the opening between the sides and your interference will
disappear.Lowering your transducer will help.Or buy a holeshot plate that also will work.  Gary
Last post June 19, 2011, 07:37:28 PM
by cooter
Last post April 10, 2011, 06:58:38 PM
Last post May 10, 2011, 01:37:48 PM
Last post September 25, 2014, 08:51:48 AM
Last post June 14, 2011, 08:03:53 AM
by edwardpic
Last post July 10, 2011, 11:19:00 PM
by calli1
Last post June 26, 2012, 03:40:47 PM
Last post June 27, 2013, 01:00:18 PM
by Zildjian
