Author Topic: Travel direction for HDSI-180 T?  (Read 10534 times)
Offline Kokanee
  • Unit(s): 598ci HD SI w/HDSI xducer , 561, 400ID
  • Software: 6.460
« on: May 26, 2013, 12:23:24 PM »
I am building a portable bracket for my XHS-9-HDSI-180 T transducer out of an old electric trolling motor. It will give me tilt adjustments in both directions and protect it. After removing the "guts" and cutting out the bottom and sides high enough for full clearance, the internal dimensions are perfect. Except - the transducer would be backwards. I am not sure, but I suspect it shouldn't matter which direction it travels?
I got the idea from a towfish post where he recessed the transducer up into the PCV body for protection. When completed, I can take my unit and transducer "bracket" on other boats. Even on my little boat with two motors there is no unobstructed view off the transom. I can clamp it to the side and adjust as needed.
Oncorhynchus nerka
Offline D S
  • Software: 7.5
Re: Travel direction for HDSI-180 T?
« Reply #1 on: May 26, 2013, 01:21:12 PM »
can u post pics of your design as im planning on doing similar project :)
stgr
Offline Kokanee
  • Software: 6.460
« Reply #2 on: May 26, 2013, 01:29:55 PM »
Sure. As soon as I finish it and make sure it works well I will post. The hardest part so far was finding an old trolling motor with motor body length long enough for a 6" transducer.
Oncorhynchus nerka
Offline Kokanee
  • Software: 6.460
« Reply #3 on: May 26, 2013, 06:05:28 PM »
Dave,
I had one of those days when the brain and hands worked well together! Here is what I have to date. Haven't figured out what to do for the top/handle, yet. The temp button has plenty of room for water movement around it, so that should not be a problem. Make sure there are no sharp edges where the cable goes up into the main shaft. I added SS brackets at the joints and used a 1/4" SS bolt with a locking nut through the motor body and existing transducer housing holes.
If I had to do this over, I would have looked for a larger diameter motor housing. This one was a MinnKota 35 from the 1980s with a 2.5" diameter aluminum and steel motor housing (no plastic).
Hope yours goes well.
Robert: not sure if this post should be here or somewhere else?
Lou
Oncorhynchus nerka
« Reply #4 on: May 26, 2013, 06:39:12 PM »
The mounting "ears" on the HDSI housing are on the front for a reason....
There is a "left SI crystal" and a "right SI crystal" in the HDSI xducer that send their individual reflection data to the processor so that the processor knows which side of the SI image to display which echos...
Mounting the HDSI xducer with the mounting "ears" to the rear will make your echo targets display on the wrong side of the SI image...
Structure and fish on the left side of your boat would be displayed on the right side of the SI display image....
Structure and fish on the right side of your boat would be displayed on the left side of the SI display image...
« Last Edit: May 26, 2013, 06:49:00 PM by rnvinc »
Offline Kokanee
  • Software: 6.460
« Reply #5 on: May 26, 2013, 06:45:30 PM »
Thank you. Good to know for my next project. On this one, all I have to do is swival 180 degrees and all should be good.
Lou
Oncorhynchus nerka
« Reply #6 on: May 26, 2013, 06:52:14 PM »
Lou
Swiveling the unit 180° will work fine...
Neat looking project you have come up with...
Last post March 26, 2010, 08:32:36 AM
by Jolly Roger
Last post May 22, 2010, 08:50:00 AM
by TMcG
Last post April 27, 2011, 02:15:58 AM
by Roddy
Last post April 24, 2012, 04:03:09 PM
Last post July 20, 2012, 06:45:07 AM
by xSilmarilSx
Last post August 07, 2015, 10:30:22 AM
Last post August 20, 2015, 11:09:13 PM
Last post August 03, 2023, 02:39:15 PM
by Papa D
