Author Topic: HDSI cable  (Read 6094 times)
HDSI cable
« on: April 23, 2012, 03:35:12 PM »
what effect will cutting the pink and blue cable on the hdsi and sending only the left and right signal to the head?
Or another way: what signal (freq) are sent over what cable color? And what effect if you cut one of them?
« Last Edit: April 24, 2012, 03:51:52 PM by sonar2000 »
Offline Rickard
Re: HDSI cable
« Reply #1 on: April 24, 2012, 03:58:49 PM »
Chuck,
Are you sure about those colors? HB may change the colors without notice, but I have never seen pink and blue wires in a transducer cable. The SI and HDsi transducers use to have the same type of cable and the wires have these functions:
Red - Temp
Black - 200/83/50 kHz
Drain wire and foil shield - Ground for temp and 200/83/50 kHz
Orange - Left SI 262/455/800 kHz
Violet - Ground for left SI
Yellow - Right SI 262/455/800 kHz
Brown - Ground for right SI
Orange is twisted with violet and yellow is twisted with brown. All ground wires are joined at a common pin in the connector.
If the black wire is cut the downward 200/83/50 kHz channel is disabled. The effect is no depth info which will make the unit slow down ping rate to almost nothing (one or two pings per second). The image gets distorted with very low resolution. I have tested this and seen the result...
Rickard
Re: HDSI cable
« Reply #2 on: April 24, 2012, 04:03:09 PM »
Not sure of the colors exactly. Was more curious about cutting a cable that affected the DI and 2d info..
Still trying to get a handle on how many elements there are in the hdsi and what they do or have effect upon.
Thanks, you are the man of transducers..
chuck
Last post March 26, 2010, 08:32:36 AM
Last post May 22, 2010, 08:50:00 AM
by TMcG
Last post July 13, 2013, 06:51:56 AM
Last post September 11, 2012, 07:30:05 AM
by gros21
Last post June 13, 2013, 11:05:36 AM
Last post November 19, 2014, 12:29:11 PM
Last post June 20, 2016, 11:24:21 PM
Last post October 02, 2016, 11:45:52 PM
