Author Topic: 998 with old transducer  (Read 3384 times)
Offline Jackk
« on: May 24, 2013, 10:56:05 AM »
I am upgrading my matrix 17 to a 998.  The 17 had a dual beam transducer.  Do I need to rerun the new one, or are they the same?
Re: 998 with old transducer
« Reply #1 on: May 28, 2013, 10:29:37 AM »
The 998 unit uses a Side Imaging (HDSi) transducer.  You will have to mount and use this new transducer to get the Side Imaging and Down Imaging sonar.  It will also give the 2D sonar but many end up mounting their HDSi transducer were it is less likely to get damaged from hitting something (but still able to give good Si/Di sonar readings) and use a second DualBeam transducer for the 2D sonar but it is usually installed inside-the-hull on fiberglass boats.  An AS-Si-DB-Y cable is needed for this.  Your Matrix 17 unit uses a DualBeam transducer.
by Sonshine Fishing
Last post January 25, 2011, 11:48:55 AM
Last post March 11, 2011, 12:39:09 PM
by bamafish
by Brian37075
by jgcox6
