Author Topic: New Di transducer . Need help  (Read 12428 times)
Offline jimf
  • Unit(s): 997ci si
« on: January 24, 2011, 11:09:51 AM »
I'm going to buy the 788ci HD DI  unit.
Plus I am going to buy a transducer saver by www.transducershieldandsaver.com
The company says that model ssc-3 will fit the XNT-9-20 transducer.
What I like to know what dos the new 788ci HD DI transducer look like ?
Is it the same as the XNT-9-SI 180T transducer ?
Huminbird says the 788ci hd di uses the XNT-9 Di T
I like to know what transducer comes close or the same size as the XNT-9-DI T transducer.
Thank you very much.
Jim Frascella
Wayne P.
  • Guest
Re: New Di transducer . Need help
« Reply #1 on: January 24, 2011, 02:28:03 PM »
The Humminbird web site does not show a picture of the DI transducer.
Transducer Shield and Saver gets sample transducers to make brackets fit all the transducer styles. Evidently they don't have a sample yet to advise you. The same goes for the Lowrance DSI transducer that is new too.
If you have a thin fiberglass hull like a bassboat, you can use the new DI transducer as a shoot thru and won't need the bracket unless you are going to put it on the trolling motor.
« Reply #2 on: January 25, 2011, 11:48:55 AM »
Actually there is a new DI transducer that is designed specifically for inside-the-hull installation: XIH-9-DI-T.  Not sure what it looks like as I have not seen one as yet.  My guess is that it is the same as the XNT-9-DI-T except that it has an external temperature sensor, but I could be wrong.
The new XNT-9-DI-T  will need a different bracket as it is shaped quite a bit differently than the other XNT style transducers (see drawing).  If you are going to mount it on a trolling motor you will have to use the AD-XTM9 Trolling Motor Adapter bracket for now until Scap at Transducer Shield & Saver makes one.
by Sonshine Fishing
Last post June 23, 2010, 10:08:49 PM
by RV Sam
Last post February 16, 2011, 06:14:59 PM
Last post October 04, 2010, 06:32:55 PM
Last post October 31, 2010, 02:44:50 PM
Last post July 16, 2013, 10:27:03 AM
Last post February 08, 2011, 02:38:59 PM
Last post February 18, 2014, 10:01:28 AM
