Author Topic: Incorrect digital readout on 997SI  (Read 15217 times)
Offline pjazzman
  • Unit(s): 997 si
  • Software: not sure
« on: May 14, 2013, 05:08:41 PM »
I've got a 997SI and the digital bottom readout stays at 2-3 ft all the time. The visual screen tracks the bottom accurately but the digital read out never is correct!!  Can anyone HELP with this problem??? Ay solutions will be greatly appreciated!! :(
Re: Incorrect digital readout on 997SI
« Reply #1 on: May 14, 2013, 05:50:23 PM »
pjazzman,
Welcome to the Side Imaging Forums!
Is there a second sonar unit running at the same time?
Does this happen when the boat is drifting and all motors and electrical devices are off?
Are you running only the HDSi transducer or are you running a two transducer configuration?
If two; which transducers and how are they connected?
Do you know someone else with a Humminbird unit that would allow you to test your unit on their  boat/transducer?  This does not have to be another 997 unit as any will work to test the 2D sonar on your 997 unit, except for those models with “3D” in their name.  Just plug up the power and transducer for the test.
Last post December 15, 2009, 10:38:32 PM
Last post December 02, 2010, 11:39:31 AM
by werethefugowee
Last post March 27, 2011, 03:46:51 PM
by KickSomeBass
Last post April 11, 2012, 08:49:42 AM
Last post December 19, 2012, 03:25:36 PM
Last post June 17, 2013, 10:13:24 AM
by Wackyracer
Last post January 26, 2022, 03:39:46 AM
by Rüdiger
Last post March 29, 2014, 02:11:42 PM
by Saltykayak
