Author Topic: 997si Screen is toooo bright.  (Read 9117 times)
Offline werethefugowee
  • Unit(s): 997si
  • Software: Downimaging
  • Accessories: speed
« on: November 29, 2010, 01:29:19 PM »
My unit is 2 years old, no problems whatever, keep the updates current, but fishing at night - the screen destroys my night vision. I do the bright/dim adjustment (on the shutdown screen) and it dims but is still WAY to bright. I've even tried sunglasses.
Any way to fix this?
Thanks in advance for any advice.
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: 997si Screen is toooo bright.
« Reply #1 on: November 30, 2010, 03:59:39 PM »
What about using a tinted shield?
My 2 cents....
Best regards / Harry
YES,......
WE SCAN!
Offline George
  • Software: Always up todate
« Reply #2 on: November 30, 2010, 04:40:01 PM »
werethefugowee
On ships they use red lights to improve their night vision.  Have you thought of trying some red cellophane, their are different degrees of red color.  If it works you could purchase red plexiglass  and bend it to hang over your screen and or make a box.
Cellophane might stick to the screen making it easy to remove.
The red might interfere with any red coloring on the display.
George
Offline Enufzed
  • Enufzed
  • Oh happy days !!
  • Unit(s): 898cx SI
  • Software: V 6.180
« Reply #3 on: November 30, 2010, 08:51:06 PM »
Try this for night viewing. When unit is on and operating in navigating mode push power on/off  switch once, this will give you a light and background screen select background and select black then select the light and move slider bar to adjust the amount of light you require.
The white is good for daytime
the blue for early morning or last light
the black screen for night
Good luck
Geoff
  • Unit(s): 997si
« Reply #4 on: November 30, 2010, 11:19:45 PM »
I,ve tried the dark background and this does help some.  I was wondering if I was missing a deep inside setting.
Thanks for your help tho.
Offline Enufzed
  • Enufzed
  • Oh happy days !!
  • Unit(s): 898cx SI
  • Software: V 6.180
« Reply #5 on: November 30, 2010, 11:53:32 PM »
Did you adjust the light slider as well whilst in  the black setting.
  • Unit(s): 997si
« Reply #6 on: December 02, 2010, 11:39:31 AM »
Lots of suggestions which leads me to believe that my unit is OK, and an "add-on" solution is in order.
I will try;
  a smoke type cover
  a Red filter type cover
  and will report back here with the results.
Thanks go to everyone for the advice.
WTF
Last post January 22, 2012, 08:28:45 PM
Last post December 15, 2009, 10:38:32 PM
Last post April 07, 2010, 09:55:07 PM
Last post July 24, 2012, 02:08:19 PM
Last post December 19, 2012, 03:25:36 PM
Last post May 14, 2013, 05:50:23 PM
Last post October 23, 2014, 05:53:40 AM
by mmikos
