Author Topic: Can I use the same unit on 2 boats with different transducers?  (Read 9717 times)
Offline Freeline
  • Unit(s): 798ci si
  • Software: 5.450
I have the original transducer on one boat, but I need to buy a new transducer for the new boat.  If I get the HD transducer for the new boat, will I have to change settings every time I switch the unit from one boat to the other?
Are there any problems having different transducers on each boat?
Offline Blackwaterkatz
  • Unit(s): 797c si / 998c si / 1198
  • Software: 5.450 / 5.700
  • Accessories: weathersense
Re: Can I use the same unit on 2 boats with different transducers?
« Reply #1 on: May 05, 2013, 09:08:03 AM »
I've done the same thing; most of the time there will be little or no changes to make, other than corrections as water conditions may change a little.
Tommy in Lowcountry S.C.
Offline Freeline
  • Unit(s): 798ci si
  • Software: 5.450
« Reply #2 on: May 06, 2013, 12:24:34 PM »
Thanks, Blackwater.  I went ahead and ordered the HD transducer.  Do you find much difference in the display with the 2 transducers?
« Reply #3 on: May 06, 2013, 08:35:35 PM »
Very little, if any at all, difference between the two, unless I use my 998 with the portable transducer, which is for a 797, so I don't get the higher definition, but it still works pretty well. When I use the 797 on the portable, it works as well as the boat and transducer I normally run it on.  :)
Offline Freeline
  • Unit(s): 798ci si
  • Software: 5.450
« Reply #4 on: May 07, 2013, 05:58:55 AM »
It seems that I may not see any difference with the HD.  I usually like to get the latest technology, but I can save myself some installation time (since both boats are already set for the original transducer) and a little money if I get another non HD transducer.
Does anyone think that I would get any benefit from the HD transducer with the 798 ci si?
« Reply #5 on: May 07, 2013, 04:04:16 PM »
Freeline,
Some notice a difference using the HDSi transducer with the 798 or 797 units and some don’t.  Almost everyone sees the difference though when you look at a screen snapshot on a larger display, like the one on your computer.
Offline Freeline
  • Unit(s): 798ci si
  • Software: 5.450
« Reply #6 on: May 07, 2013, 05:04:12 PM »
Thanks, Greg.  Will the HD mounting bracket fit the same holes as the original transducer bracket that I will be removing?
« Reply #7 on: May 08, 2013, 11:33:16 AM »
No they will not Freeline.  These transducers use different mounting hardware which have different mounting hole patterns.
Last post April 29, 2011, 09:29:42 PM
by xSilmarilSx
Last post August 04, 2011, 10:13:41 PM
by stratofisher
Last post November 18, 2011, 03:34:58 AM
by Rüdiger
Last post December 29, 2011, 01:53:01 PM
Last post February 24, 2012, 01:19:27 PM
Last post April 20, 2013, 05:50:41 PM
by Jay415
Last post February 09, 2015, 03:53:30 PM
Last post July 18, 2015, 09:21:43 PM
by shanemcg83
