Author Topic: ALL SI Models - SI transducer adjustable for boats stored in the water  (Read 9119 times)
Offline gofission
  • Unit(s): PiranaMax 160, Matrix 37, 798ci HD SI
Model:
ALL SI Models
Suggested Upgrade:
Explanation:
Boats that are too big for trailers need to lift the boat on a lift or hire a diver to make transducer adjustments. Future TD mount designs should take into consideration that loosening the mounting screws to make adjustments can cause water to leak into the transom core materials and lead to damage. Ideally one piece should be mounted and sealed to the hull. All adjustments should be made without disturbing the sealed screws.
Added in Software Version:
Comments on Update:
« Last Edit: April 29, 2011, 09:29:04 PM by gofission »
Offline xSilmarilSx
  • Software: 6.250 - 5.320
It's why people screw a big piece of UHMW (plastic) to their transom( like 1/2"thick), and then screw the transducer into the UHMW backing.
Last post June 27, 2010, 10:51:19 AM
Last post February 18, 2011, 08:52:26 AM
by Daniele_Mari
Last post April 25, 2011, 10:57:06 AM
Last post July 28, 2011, 10:07:29 AM
Last post March 15, 2013, 11:48:02 AM
Last post June 17, 2013, 10:13:24 AM
by Wackyracer
Last post May 18, 2014, 07:59:29 PM
by Scrutch
Last post July 09, 2023, 06:14:42 PM
