Author Topic: 600 volt THHN wire  (Read 9082 times)
Offline 234rick
600 volt THHN wire
« on: April 30, 2013, 07:45:10 PM »
I hope someone can answer this because I can't find anything online. Is it ok to use cooper stranded THHN wire that is used in conduit for house wiring for a 20' run for a 798 HD. What I have is #14 & it has 19 strands.
Re: 600 volt THHN wire
« Reply #1 on: April 30, 2013, 09:35:07 PM »
I think that wire should be fine.  The 14 guage will be plenty large for a 798.  I think the THHN is rated as gas and oil resistant.
I think you are talking about individual wires.  If I were doing the install, I would twist the wire to help reduce the possibility of interference.  (Tie one end of the wire to something stationary and the other end in a drill chuck....pull tight while twisting.)
Last post March 09, 2011, 09:12:22 PM
by Ddorriety
Last post November 19, 2010, 09:27:06 AM
by stillbear
Last post May 25, 2011, 11:14:10 AM
Last post May 20, 2012, 02:36:08 PM
Last post September 02, 2015, 04:10:47 PM
Last post April 26, 2018, 08:44:13 AM
by Boots
Last post September 09, 2018, 07:58:26 AM
Last post April 10, 2022, 03:00:41 PM
by tournevase
