Author Topic: 16 volt system  (Read 9779 times)
Offline scottkh
  • Unit(s): 1197, Solix 12 and 15, ML M360
  • Software: 4.75
  • Accessories: Networked
16 volt system
« on: April 07, 2022, 05:28:17 PM »
Anyone running Solix units along with network switch, mega live and mega 360 on 16 volt battery?   How do you like it?
Offline danlaboucane
  • Unit(s): ,798 hd onix8 ct , solix 12 msi
  • Software: 7.6 ,3.03
  • Accessories: sm3000+eth 5 port to get SI on onix CT,
Re: 16 volt system
« Reply #1 on: April 09, 2022, 05:15:56 PM »
Not I but is there any benefits to running on 16V ?
Re: 16 volt system
« Reply #2 on: April 09, 2022, 10:26:19 PM »
I’ve read a few posts thru the forums of guys curious if higher voltage makes the units function better or give better images  ...
I have yet to see any quantitative positive results  ...
Offline tournevase
  • ARCHAEOLOGICAL SURVEY
    • GRAS
  • Unit(s): HELIX 10 G4N CHIRP MEGA SI +
  • Software: AUTOCHART PRO
Re: 16 volt system
« Reply #3 on: April 10, 2022, 03:00:41 PM »
the manufacturer specifications gives 10 to 20 v for helix and only "12v" with no range for solix
it is a stupid idea to think that the performances of such an equipment will be improved with more volts because in electronics devices the supply voltage is internaly stabilizated
you cant test ... if you are rich enought to change fuses in the best case and buy a new device in the worst
Tournevase
Last post March 09, 2011, 09:12:22 PM
by Ddorriety
Last post November 19, 2010, 09:27:06 AM
by stillbear
Last post February 28, 2011, 03:14:02 PM
Last post May 25, 2011, 11:14:10 AM
Last post April 30, 2013, 09:35:07 PM
Last post April 03, 2014, 11:12:28 AM
Last post August 16, 2015, 12:15:11 PM
by Rickard
Last post April 26, 2018, 08:44:13 AM
by Boots
