Author Topic: HBPC problem  (Read 12548 times)
Offline spanna
  • Unit(s): 598CXIHDSI piranha 1x 100sx wide 128
  • Software: n/a
HBPC problem
« on: April 28, 2013, 06:07:11 PM »
I have downloaded hbpc but when I try to open it I get "humminbirdpc exe has encounted a problem and needs to close" has any body had this or got any idea what the problem is? help please. Spanna
Re: HBPC problem
« Reply #1 on: April 29, 2013, 01:39:13 PM »
Are you trying to run this file or open it with some application?
Offline spanna
  • Software: n/a
Re: HBPC problem
« Reply #2 on: April 29, 2013, 05:59:31 PM »
Hi Greg .thanks for the reply I have tried both ,same result
Re: HBPC problem
« Reply #3 on: April 30, 2013, 03:50:00 PM »
Don’t know.  Maybe some of the computer gurus on here can help out.
Try uninstalling HumminbirdPC and download it again and install from the new download file.
Offline 4d-rock
  • Unit(s): 997c SI, 778c, 570
  • Software: 6.30
Re: HBPC problem
« Reply #4 on: April 30, 2013, 05:37:33 PM »
First of all, which operating system are you using (Vista, 7, 8, etc.).
I'm sure there are some version that may not be compatible.
I would first re-downloading the install file and then re-installing.
You could also try to download an older version of the software too to see if anything different happens.
I've run across some problems with exe files that require you to right click it and select 'Run as Administrator' rather than just double clicking.  Could try that as well.
Offline spanna
  • Software: n/a
Re: HBPC problem
« Reply #5 on: April 30, 2013, 06:42:55 PM »
Hi 4d-rock thanks for the help I am running XP v5.1 s/3. I have just downloaded an older version of HBPC v3.0.26 and it opens Ok so thats a start maybe that will have to do. Do you or any body know what the differance is or any other suggestions? thanks again ,spanna
Offline spanna
  • Software: n/a
Re: HBPC problem
« Reply #6 on: April 30, 2013, 08:48:48 PM »
 ;D problem solved changed anti virus thanks again for the advice .All I have to do now is lean how to use it.
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
Re: HBPC problem
« Reply #7 on: April 30, 2013, 11:02:48 PM »
Offline spanna
  • Software: n/a
Re: HBPC problem
« Reply #8 on: May 01, 2013, 04:27:12 AM »
Thanks Little Gazebo I printed it for when I get past the first screen
Last post January 25, 2011, 10:22:04 PM
Last post July 26, 2012, 09:14:38 PM
by musky_ken
Last post May 22, 2015, 02:21:41 PM
by johncos
Last post February 19, 2015, 09:10:42 AM
by LittleGazoo
Last post June 05, 2014, 12:49:02 AM
by LittleGazoo
Last post July 08, 2019, 10:38:08 PM
Last post March 04, 2020, 07:26:45 PM
by Fisherdan
Last post April 04, 2020, 10:10:14 PM
