Author Topic: problem latest version of HBPC  (Read 12962 times)
Offline nonick79
« on: February 01, 2012, 12:59:47 PM »
Hi,
since a view hours i´m trying to install the newest version of the HB-PC Software, but it didnt run.
Im using a Win XP PC with latest Java update installed. The older Version 3.x of the Software ist working
correctly, but im not able to start the new one after installing it.
I also tryed the WIN95 compability modus.
Maybe somebody could help me!
The error pop up always says: HBPC.exe located a problem and needs to be closed.
Greetings from germany
Maik
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: problem latest version of HBPC
« Reply #1 on: February 04, 2012, 05:42:37 AM »
Make sure this is right before downloading new up date. Gary
Instructions:
Prior to downloading this software, please make sure of the following: 1. You need to be running Java version 6 update 26 at a minimum. 2. You should have all of the latest Windows Updates completed. 3. Download this program to your PC. Run the program and follow the installation instructions. NOTE: When using a unlocked SD card that has never had Humminbird waypoints stored on it, you should first follow the instructions on the following FAQ to avoid an error message that reads Data Error Null. http://www.humminbird.com/FAQ.aspx?ContentId=3148 CAUTION! We highly recommend that you restore the defaults on your Humminbird unit prior to downloading any new software as it can create complications that can only be fixed at the factory.
Posted by: RGecy September 10, 2011, 12:35:06 AM
Offline nonick79
« Reply #2 on: February 06, 2012, 05:10:33 AM »
Hi,
thankx for your reply, but the problem is that i followd point 1 to 3 and still have the
problem, that i´m not able to run the program.  :(
I have Win XP and also tryed the compability modus, but that doesnt work neither.
Version 3.x is running correctly, but i´m not able to download the tracks from my
728 unit.
Livetracking with Dr. Depth is possibly, but not downloading tracks or updating
the software on the unit.
Greetings
Maik
Offline stillbear
  • Stillbear
« Reply #3 on: February 06, 2012, 07:19:25 AM »
Contact HB customer support explain your problem. Please keep us posted. Gary
Offline musky_ken
  • Unit(s): 778c
  • Accessories: quad view
« Reply #4 on: June 12, 2012, 09:07:59 PM »
Hey did you ever find out what the problem was? I'm having the same issue with mine.  Ken
Offline musky_ken
  • Unit(s): 778c
« Reply #5 on: July 26, 2012, 09:14:38 PM »
Well I found out what the problem was with mine so I will post up in case it helps anybody out.  I'm running xp pro and humminbird pc 4.3.3 and had a conflict with zone alarms free firewall.  Disabling did nothing.  Only after uninstalling the firewall could I get 4.3.3 to go.  I ended up reinstalling an older version of zone alarms and everthing is a go.
Last post March 10, 2010, 01:28:10 PM
Last post April 21, 2011, 11:46:37 PM
by Enufzed
Last post December 12, 2011, 01:38:22 PM
Last post December 12, 2011, 01:43:21 PM
Last post October 25, 2013, 05:57:07 PM
by LittleGazoo
Last post May 22, 2015, 02:21:41 PM
by johncos
Last post March 26, 2015, 11:10:17 AM
Last post March 11, 2015, 09:53:03 AM
