Author Topic: 998 question how do i stop the graph coming out  (Read 17584 times)
Offline junoir
  • Unit(s): 998
  • Software: 6.610
« on: April 19, 2013, 06:44:07 AM »
happens far bit in deeper water maybe somwthing to put in next update
« Last Edit: April 19, 2013, 06:46:04 AM by junoir »
Re: 998 question how do i stop the graph coming out
« Reply #1 on: April 19, 2013, 11:46:44 AM »
Could you explain what you are meaning by “the graph coming out”?
It looks like the unit is showing some sort of interference.  Was there another sonar unit running at the same time?
What transducer was in use when you made this screen snapshot?
Does this happen with the motor and all other electrical devices turned off?
Offline junoir
  • Unit(s): 998
  • Software: 6.610
« Reply #2 on: April 23, 2013, 05:26:52 AM »
im running the tm260 transducer the snap shoot was taken on a drift so no motor just  vhf radio and a garmin gps and by graph i was just meaning the way the depth lines are
« Reply #3 on: April 23, 2013, 11:05:00 AM »
“tm260 transducer” is that the Airmar transducer?  I have no experience with this transducer.
I would try shutting off all electrical devices and see if it goes away or not
Offline junoir
  • Unit(s): 998
  • Software: 6.610
« Reply #4 on: April 24, 2013, 05:06:41 AM »
yep its airmar
thanks i have a play around next time it does it only seems to do it in 900ft+
« Reply #5 on: April 24, 2013, 11:19:08 AM »
What Beam Select menu setting are you using?
Offline junoir
  • Unit(s): 998
  • Software: 6.610
« Reply #6 on: April 25, 2013, 05:56:12 AM »
just 50khz
Last post February 16, 2010, 04:05:29 PM
Last post March 22, 2010, 08:57:39 PM
by blharr4400
Last post June 18, 2010, 03:55:30 PM
Last post September 22, 2011, 07:05:48 PM
Last post May 05, 2015, 11:12:17 PM
Last post January 09, 2016, 04:58:45 PM
by N9Phil
Last post October 17, 2016, 08:28:48 AM
Last post June 22, 2017, 09:47:14 PM
