Author Topic: no temperature graph  (Read 9254 times)
Offline garinis33
  • Unit(s): 997
  • Software: 5.3
« on: June 17, 2010, 03:53:46 PM »
Hi. I cant see the temperature graph on my 997. I restored defaults, i set the  temperature graph on at sonar menu tab with no results. I tested a different unit on my boat and it works fine. Any advice?
Re: no temperature graph
« Reply #1 on: June 17, 2010, 04:24:30 PM »
Are you asking about the graph that displays history or the screen that displays the current temp.  is is possible to snapshot and send a picture.
« Reply #2 on: June 17, 2010, 11:57:42 PM »
Test your unit on the other guys boat also.
What about if you change one of the readouts on your display to temperature?  Does it show the temperature in the readout?
What view are you in when looking for the temp graph.  I think it will only show in the 2d view only.
Offline garinis33
  • Unit(s): 997
  • Software: 5.3
« Reply #3 on: June 18, 2010, 03:13:51 PM »
I'm asking about temperature
graph over the main Sonar View to show temperature changes correlated to
recent sonar history.
I tested my unit on other boat with no result.
I tried to change one of readouts but there is not temperature readout option to select.
I use 2d view when looking for the temp graph
« Reply #4 on: June 18, 2010, 03:55:30 PM »
You might need to be in adsvanced mode to select temp display.
Not sure about your temp graph for history.  I thought that was part of the weather adapter feature.
« Last Edit: June 18, 2010, 03:57:45 PM by sonar2000 »
Last post September 22, 2011, 07:05:48 PM
Last post April 25, 2013, 05:56:12 AM
by junoir
Last post May 24, 2013, 09:46:25 PM
Last post October 16, 2013, 05:43:40 PM
by sstone2591
Last post June 22, 2017, 09:47:14 PM
Last post April 19, 2018, 09:53:03 AM
by Colorado #5
Last post March 06, 2019, 04:12:29 PM
by P_Frost7
Last post January 21, 2020, 03:02:45 PM
by Mark Saikaley
