Author Topic: Ram Mounts Require Backing Plates????  (Read 11580 times)
Offline EZM
  • Unit(s): ONIX 10 SI, 898c HD SI,858c (x2), 688ICE
  • Software: vX.XXX and v6.570
  • Accessories: Terrova i-Pilot Link, 5 port Ethernet
« on: March 20, 2013, 12:42:18 PM »
I think I have this figured out but wanted to bounce it off a few others for any ideas/suggestions .......
I will have a 898 and 858 mounted on top of the dash (boat is 1800 Tyee). The units and ram mounts are relatively heavy.
Screwing the ball base into the dash board top seems pretty flimsy to me. I saw lot's of online install videos and guys where just driving screws into their dashes ......
I figured, for added strength, I would add a backer plate below the dash and use stainless bolts/nuts to add strength .... any thoughts?????
I have fabricated up these blocks from a sheet of HDPE 3/4" thick - the plates were cut to 4"x4" and drilled out to recieve the bolts in the same pattern as the ball mount on the top of the dash.
Offline EZM
Re: Ram Mounts Require Backing Plates????
« Reply #1 on: March 20, 2013, 12:43:34 PM »
Here is the backer plate ....... (notice the Tim Horton's coffee cup in the first picture in the background ....lol).
« Last Edit: March 20, 2013, 12:46:59 PM by EZM »
« Reply #2 on: March 20, 2013, 02:35:12 PM »
I guess it depends on how strong the material is that you are screwing in to, but a backer plate always makes sense!  Looks very nice and clean and very simple to do vs having to repair a damaged dash!
« Reply #3 on: March 20, 2013, 02:52:59 PM »
You're right about the screws.
I would use bolts and nuts if possible.
It looks like a little bit of overkill, if the material to
fasten to has any strength.
I would have just used stainless steel hardware with
flat washers at each end.
But, it's a nice and secure method.
« Last Edit: March 20, 2013, 02:54:31 PM by ITGEEK »
Offline yenrec
« Reply #4 on: April 07, 2013, 07:47:39 PM »
I installed mine on thin fiberglass, my old small unit stayed fine but with my 898c i backed it with 3/4" marine grade plywood and it is solid as a rock! better safe than sorry!
Offline TroyBoy30
  • Unit(s): 1198
« Reply #5 on: April 08, 2013, 08:45:49 AM »
most already use bolts and nuts for installs.  some even use large washer just in case
Last post January 07, 2011, 12:59:17 AM
by tellicorick
Last post April 17, 2012, 10:18:56 AM
by Patty
Last post July 11, 2012, 06:54:36 PM
by gramps50
Last post November 27, 2012, 07:24:03 AM
Last post January 11, 2013, 02:02:24 PM
Last post September 19, 2018, 09:01:43 AM
by Sawyer
Last post August 03, 2022, 08:47:15 PM
Last post September 25, 2023, 08:35:38 AM
by jimf
