Author Topic: Mounting plates  (Read 9796 times)
Offline BryanB
  • Unit(s): 798CI SI
  • Software: 5.840
Mounting plates
« on: June 29, 2012, 02:40:50 PM »
Does anyone know where online or store that sells the Teflon mounting plates that folks have been using so they can move an adjust their Transducer , would rather avoid drilling anymore holes.
Thanks...
Offline BryanB
  • Unit(s): 798CI SI
  • Software: 5.840
Re: Mounting plates
« Reply #3 on: June 29, 2012, 03:50:36 PM »
Sweet, thanks allot guys!
Offline gramps50
  • Unit(s): 597ci HD DI
  • Software: 6.09
Re: Mounting plates
« Reply #4 on: June 29, 2012, 05:23:08 PM »
I took 2 cutting boards and glued them together, I used 1/2 thick cutting boards. Used Gorilla glue to glue them together
Offline alumazilla
  • Unit(s): 798ci Si NVB
  • Software: 5.840
  • Accessories: none
Re: Mounting plates
« Reply #5 on: July 05, 2012, 05:03:02 PM »
Good Job Gramps! I went to H.D. and got the shortest piece of 1X4 PVC board and sliced a small 4" section.
Also bevelled the bottom edge to prevent turbulance
Re: Mounting plates
« Reply #6 on: July 11, 2012, 02:35:05 PM »
What did you guys use to attach the boards to your boat with?
Offline gramps50
  • Software: 6.09
Re: Mounting plates
« Reply #7 on: July 11, 2012, 06:54:36 PM »
I attached mine with 2 SS 1/4x20 bolts and 3M 5200. The bolt holes are countersunk. Ran a bead of 5200 around the back and the bolt holes, also a little in the front holes. Put it in place and tightened the bolts and let the 5200 dry & cure, takes several days depending on the weather.
No leaks and only 2 holes below the water line
Last post January 07, 2011, 12:59:17 AM
by tellicorick
Last post January 28, 2011, 07:32:04 AM
by Wayne P.
Last post April 17, 2012, 10:18:56 AM
by Patty
Last post April 08, 2013, 08:45:49 AM
by TroyBoy30
Last post February 09, 2014, 01:21:14 AM
Last post March 02, 2014, 02:55:53 PM
Last post August 17, 2016, 09:59:25 AM
by Sewerdude
