Author Topic: Can a 598SI and a 561 share the ducer?  (Read 10017 times)
Offline Kokanee
  • Software: 6.460
« on: March 16, 2013, 08:15:35 PM »
Just moved up to a 598SI and would like to have my 561 on, also. To avoid cross-talking with two ducers in the water (XNT-9-SI-180-T and an XNT-9-20-T), is there a splitter cable so the 561 can use the 20/60 dual cone signal off the XNT-9-SI-180-T? That way the 598 could be full screen SI and the 561 would be Switchfire.
Oncorhynchus nerka
Re: Can a 598SI and a 561 share the ducer?
« Reply #1 on: March 19, 2013, 09:01:51 AM »
No, there is no splitter cable that allows two sonar units to use one transducer at the same time.  The best you could do would be to install a Unit Switch and select which unit would be using the XNT-9-Si-180-T transducer, but only one would be able to use it at a time.
Last post February 10, 2010, 08:03:50 AM
Last post December 23, 2012, 03:36:54 PM
by wolfs4evr
Last post April 18, 2013, 03:27:06 PM
Last post February 17, 2014, 06:07:14 PM
by gmintimidator
Last post October 31, 2014, 08:34:32 PM
Last post December 23, 2020, 10:01:00 PM
Last post February 23, 2022, 08:52:03 AM
by bbheli
Last post June 12, 2022, 09:58:39 PM
