Author Topic: Setting the time on 998c HD SI  (Read 20813 times)
Offline Midtin
  • Unit(s): 998c HB Si
« on: February 24, 2013, 04:27:29 PM »
Where do i go to set the time? i'm a rookie at this, can't ya tell?   ;D
THANKS,  MT :)
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: Setting the time on 998c HD SI
« Reply #1 on: February 24, 2013, 09:54:35 PM »
It will get the time and date from the GPS receiver data.
You don't have to double post.
Offline Midtin
« Reply #2 on: February 24, 2013, 10:26:45 PM »
Sorry, i removed one  Thanks for the info
MT
« Reply #3 on: February 25, 2013, 12:08:03 PM »
You need to look under the setup menu tab to set your unit to the Local Time Zone or to turn On/Off Daylight Savings Time (which is coming up this next month).
Offline Midtin
« Reply #4 on: February 25, 2013, 04:35:29 PM »
Greg i've done that, but the time didn't change. I'm thinking it will when i get on the water and the gps finds me.It has me now here at home but i have not moved the boat.I thought it would change after i turned the unit off and back on, but it did not.
I can wait a few days and it will be right ;)
Thanks,   MT
« Reply #5 on: February 26, 2013, 10:15:14 AM »
It should not matter if you are at home or on the water.  If the GPS is showing a location it should have the date and time from the satellites, which you can offset the time using the menus I stated.  Did you check this outside on the boat and if so was the unit running in the normal operating mode (not in a Simulator mode)?
Offline Midtin
« Reply #6 on: February 26, 2013, 01:44:54 PM »
It's inside, It shows a circle at my home and the lake which is 1/2  to a mile away. It's in NORMAL ,ADVANCED, Daylight saving is on, and in central time.
THANKS  MT
« Last Edit: February 26, 2013, 01:57:04 PM by Midtin »
Last post April 09, 2021, 09:01:09 PM
Last post October 31, 2010, 09:52:32 PM
Last post August 13, 2011, 06:07:53 AM
by ericmx
Last post June 07, 2012, 07:12:10 PM
by LocDown
Last post April 11, 2013, 09:09:13 PM
by Rotus623
Last post February 12, 2013, 01:15:58 PM
by stoporilshoot
Last post April 29, 2013, 03:11:51 PM
Last post June 18, 2015, 08:47:37 AM
