Author Topic: Setting up 997c and 998c  (Read 8275 times)
Offline bamablacksmith
  • Unit(s): 997
« on: June 05, 2012, 09:22:02 PM »
Ive got a 997c that ive had for 2 yrs and I just received a new 998c. All software is up to date. I also purchased the AS interlink module and plan on sharing all info.
Questions:
Do I need to install the GPS antenna for the new unit?
What are the pros and cons?
Doc Stressor
  • Guest
Re: Setting up 997c and 998c
« Reply #1 on: June 07, 2012, 12:33:07 PM »
I just plugged the existing transducer, power, and GPS connectors from my existing 997 into my 998.
Everything works fine. I use the 997 as a backup. The head units are interchangeable.
  • Unit(s): 997
« Reply #2 on: June 07, 2012, 01:07:05 PM »
What I meant, is that I am going to be using both units; one at the bow and one at the console, and will be using Interlink to share data. Can I make this work with only one antenna or do I have to use both?
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #3 on: June 07, 2012, 07:12:10 PM »
Yes, tell the unit with the antenna to share it on the network ..or you can plug the GPS puck directly into the interlink.
Last post May 10, 2010, 12:25:50 PM
by Lugworm
Last post September 23, 2010, 08:03:47 AM
Last post October 31, 2010, 09:52:32 PM
Last post August 10, 2011, 10:03:44 AM
by BaitCaster
Last post August 13, 2011, 06:07:53 AM
by ericmx
Last post February 26, 2013, 01:44:54 PM
by Midtin
Last post January 01, 2014, 11:12:56 PM
by Rotus623
Last post June 18, 2015, 08:47:37 AM
