Author Topic: GPS antenna upgrade  (Read 10132 times)
Offline hoselrocket
  • Unit(s): 997csi
  • Software: 4.75
  • Accessories: barometer
GPS antenna upgrade
« on: December 16, 2009, 11:30:26 PM »
Does anyone know, if the new 50 channel high accuracy Gps antenna will update any faster than the stock antenna?  When i am under trolling motor power (going slow) the gps fix seems to be very slow.
Offline George
  • Software: Always up todate
Re: GPS antenna upgrade
« Reply #1 on: December 17, 2009, 08:42:57 AM »
hoselrocket
The AS GR50 should be faster then the AS GR16, it will give you more accurate position readings.  Also, the latest update 4.700 improves the updating speeds.
George
« Reply #2 on: December 17, 2009, 11:46:15 AM »
The 4.700 software that George referred to is not available for all units just yet.  Many will get this as a software upgrade in January I’ve been told but not all of the models that will get it.  This enhanced GPS refresh rate will work with the GRHA, GR50 and GR16 GPS Receivers (but not the older GR4 and GR4RD GPS Receivers).
Last post June 29, 2012, 05:14:25 PM
by bomac
Last post February 12, 2013, 04:55:14 PM
by jbailey
Last post March 21, 2013, 02:43:42 PM
by jimmybass2
Last post March 25, 2013, 02:20:15 PM
by Rotus623
Last post April 30, 2014, 09:16:26 PM
by wolfman111471
Last post August 13, 2015, 10:43:55 AM
by Gimp
Last post August 17, 2015, 02:56:54 PM
by dae06
Last post May 08, 2018, 10:57:37 PM
