Author Topic: GPS Antenna confusion  (Read 8706 times)
Offline jimmybass2
  • Unit(s): Onix 10ciNT, 10ci SI NT, (2)8 ci CT
  • Software: 2.72
  • Accessories: 360bow,Navionics+, LakemasterSmartstrike
« on: March 20, 2013, 11:30:25 PM »
I'm confused about the GPS Pucks. My BRAND NEW 1198 came with a puck labeled "Precision GPS Module" on it's surface.  My slightly older 898 (non-HD version) came with a "AS-GR50".
Is the one labeled "Precision GPS Module" (from the 1198) one that has a Compass?
If not, what are the differences between the 2 listed above? (precision vs 50)
Should I care?
Thanks in advance for the help.
Jim
Re: GPS Antenna confusion
« Reply #1 on: March 21, 2013, 12:49:37 AM »
GR50 is the old version.  I have not checked all the specs on the new precision gps receivers, but i am sure they are faster and more accurate than their predecessors.
Offline Trytoofish
  • Software: 2.0, 7.51,
« Reply #2 on: March 21, 2013, 07:02:32 AM »
Maybe Greg can elaborate on the difference,if any.
Try Too Fish  Forced To Work
« Reply #3 on: March 21, 2013, 01:42:04 PM »
The one marked “Precision GPS Module” is the newer GRP and it does not have the Heading Sensor in it (that is the GPS-HS).  It will work about the same as the older GR50 GPS Receiver but there are some differences.  I have not seen the accuracy test data yet but they GRP should be as accurate as the GR50 (2.5 meters).
Offline jimmybass2
  • Software: 2.72
« Reply #4 on: March 21, 2013, 02:43:42 PM »
Thanks as always, Greg, for your ongoing help! You are a key reason why I've been brand-loyal for 20+ years!!!
Thank you to the rest of you for also replying!!!
Now, can any of you melt the Wisconsin lakes???
Jim
Last post May 17, 2010, 06:16:42 PM
by Deltaden
Last post June 29, 2010, 09:03:53 AM
by matt888
Last post January 06, 2011, 10:54:41 AM
Last post February 12, 2013, 04:55:14 PM
by jbailey
Last post February 01, 2013, 04:23:48 PM
by Jim Jack
Last post March 14, 2013, 09:58:12 PM
by Gator
Last post February 02, 2014, 12:47:43 PM
by Dieago
Last post April 30, 2014, 09:16:26 PM
by wolfman111471
