Author Topic: Terrova Transducer  (Read 8947 times)
Offline Kenneth Wright
  • Unit(s): 798ci Si Combo, & 153
  • Software: 5.450
  • Accessories: none
Terrova Transducer
« on: February 23, 2013, 09:11:53 PM »
New member, no dumb new member, I bought a used Terrova 80/AP/US2, which has a transducer on the foot.
I have a small pontoon boat with the wife's little HB153 tranducer attached in the rear. I have bought a 789ci and had
the tranducer in back on other side pontoon but I think I'm getting cross-talk. I really don't have any place up front to
mount it. My question is-the terrova transducer, can I use it by buying an adapter and get side imaging? I would appreciate
any help I can get, Thanks in advance Ken
Re: Terrova Transducer
« Reply #1 on: February 23, 2013, 10:33:00 PM »
The US2 transducer in the Terrova is only for 2D and will not work for SI.
  • Software: 5.450
  • Accessories: none
« Reply #2 on: February 24, 2013, 07:25:57 PM »
Thanks for the reply, I was afraid of that. guess I'll go back to the drawing board and try to find a location. I have never been real happy
with what I see but I'm sure it is my fault. Is it a sure bet with two transducers within 5' of one another with same frequency that they will interfere with each other? Could I get a "Y" cable and run the 798 & 153 off the 798 transducer? Thanks Ken
« Reply #3 on: February 25, 2013, 11:58:03 AM »
The Y-cables do not work like that Kenneth.  There is no Y-cable or switch that will allow both units to use the same transducer at the same time.  Transducer Switches allow either unit to work with a transducer but not both at once.
You can try turning the Noise Filter menu on and up on the 798 unit to filter out the sonar cross-talk.  This is called the Filter menu on the 153 unit.
  • Software: 5.450
  • Accessories: none
« Reply #4 on: February 25, 2013, 05:08:02 PM »
Thanks, I had looked at that but didn't know what frequency it would filter out. I'll give it a try. Thaks again!!!!!!!!!!!
Last post May 04, 2010, 07:02:27 PM
by Louis
Last post February 14, 2011, 09:52:42 PM
by weedsnager
Last post May 15, 2012, 11:16:50 PM
by Roddy
Last post January 19, 2013, 11:53:11 PM
by reddog
Last post March 06, 2013, 05:39:57 PM
by jimmythegreek
Last post May 08, 2013, 02:13:32 PM
by BillM
Last post October 16, 2013, 06:23:30 PM
by J.Miles
Last post March 25, 2014, 10:54:20 PM
