Author Topic: software 6.3?  (Read 14559 times)
Offline jbailey
  • Unit(s): 788ci
  • Software: 6.3
  • Accessories: quad beam,speed tempsens,
software 6.3?
« on: January 29, 2013, 06:02:12 PM »
can anyone tell me what changes software version 6.3 will make to my 788 ci? It seemed to work pretty good the way it was. I just loaded the new software in it now im just waiting for the ice to melt on the lake.
Re: software 6.3?
« Reply #1 on: January 29, 2013, 06:07:14 PM »
If you will search the forum you will find a lot of code issues and information.  Use the search box at the top. There are a number of postings.
Re: software 6.3?
« Reply #2 on: January 30, 2013, 11:00:12 AM »
If you had the previous software (5.840) loaded before installing the 6.300 software than you got the following but if you had an older version of software you got even more!
On NMEA output the baud rate has been locked in at 4800.
Bug fixes to enhance importing a large number of waypoints from an SD/MMC card.
For Side Imaging units, Auto Ranging has been fixed.
Improved sonar performance in shallow water.
In addition, several User Interface Enhancements were added:
Menu Arrow update - Previously when there were no further options the arrow would change to a lighter color.  Now there is no arrow shown when there are no further options available.
Style selection for Course Projection Lines - this allows you to select either an arrow, line or line with tick marks.  (Only on Chart plotter products, not Track plotters)
Waypoint Proximity Flags - allows you to display or hide waypoint flags for the ten closest waypoints to the boat or active cursor.  The flags show the distance from the boat to each waypoint.  These flags are influenced by the zoom level and boat speed.  They are only displayed if the chart range is less than .5 sm and the boat is traveling less than 15 mph.
Can be set to Hidden or Visible.  The default is Hidden
TTG Readouts on all Units - added to some models that did not previously have this available in the Nav Readouts sections
Lower Range Expansion - Lower Range can now be set to auto or manual.  In manual mode, it can now be set to as little as two feet.
Hide Track - you can now make a specific track visible or hidden through the Waypoint Management Menus
Scaled Boat Icon - The Boat icon size now changes depending on the chart scale the unit is set at.  There are three sizes:  Small, Medium and Large(current icon)
Display Assigned Waypoint Icon in Readout Boxes - blue dot icon is no longer used.  Actual assigned icons now show.  (only on chart plotter, not track plotter units)
Disable Nav Data Auto Upload for SD Cards - Navagation Data stored on an SD card will no longer update automatically.  You will now be prompted as to whether you would like to update the Nav Data.
Track Memory Warning - notifies the customer when they are within 10 minutes of filling up their track memory and starts overwriting data
Timer - allows you to open a dialog box to setup and start a time.  The countdown can be view via a selectable readout as well as in the setup box.  When the timer is started the clock counts down from the amount of time set in the dialog box.  This feature is part of the Alarms Menu Tab.
Vessel Offset - allows you to display more of the Chart View based on the speed of the boat.  Vessel Offset works with Offset Speed.
AIS functionality - added to 700 HD series products.
Quick Setup - allows immediate set up of Water Type and Max Depth if the unit has never been turned on before or the defaults have been reset
Sea Bed Off - default has been set to off (on chart plotter products only, not track plotters)
No Auto sensitivity on Imaging - auto sensitivity is no longer active on any Down Imaging or Side Imaging products.  This change was made because these type products function best with custom settings.
North Up Indicator - An arrow displays ont screen showing which way is North even when the chart is oriented to heading or course up.  this is located in the Chart Menu Tab, it can be set to On or Off.  The Default setting is Off.
Casting Rings - Allows you to display a circle around each waypoint on the Chart View based on the zoom level set.  This menu option sets the distance that the Casting Ring will be displayed from the waypoint.  Settings are Off to 150 ft; Default is Off.
Auto Zoom on Chart - sets the Chart view to zoom automatically based on the speed of the boat.  Setting are: On or Off.  Default is Off
Auto Range on Chart - when turned on, sets the chart scale to the lowest range so that only the boat icon and the next waypoint in the route are displayed.  This feature only activates when navigation is underway.
Skip Next Waypoint Improvements
Reset XTE - is only available during navigation.  When selected, the cross track error will be recalculated from the boat's current position to the next waypoint in the route.
Chart Orientation - allows you to select whether the Chart and Combo Views should be drawn North-Up, Heading-Up or Course-Up.  Default = North-Up
Chart Declutter - removes all chart layers except for land outlines, waypoints, routes and tracks.  The chart will stay decluttered for 10 seconds and then it will refresh to previous view.
Route Drawing Improvements
Stop Tracking - under Current Track, you have the option to Stop Tracking which clears the current track and the unit will not save trackpoints.
Offline jbailey
  • Unit(s): 788ci
  • Software: 6.3
Re: software 6.3?
« Reply #3 on: January 30, 2013, 08:18:28 PM »
Thanks Greg. Wow thats alot of updates and i think i have an older version. Should be interesting to try my unit out if spring ever gets here.
by RuffWood
Last post August 31, 2013, 11:00:33 AM
by Ken L
Last post January 07, 2014, 08:23:04 AM
by ALOTANOTA
Last post April 02, 2014, 03:35:56 PM
by Bowhunter1
Last post May 07, 2014, 10:57:17 AM
Last post August 07, 2014, 04:42:13 PM
by AaronB
Last post July 28, 2014, 06:19:28 PM
by zdriver
Last post September 09, 2014, 02:30:01 PM
by snuffer
