Author Topic: gps operation  (Read 6823 times)
Offline tonyrdiver1
  • Unit(s): hummimg bird 597 hd ci
  • Accessories: no
gps operation
« on: January 13, 2013, 06:41:33 PM »
I have a hummingbird 597hd ci combo unit.the problem I am having is with the gps. I cant seem to pin point a location.as soon as I get close with in 40ft or so it tells me I passed it . I have to use my old hand held gps to pin point a waypoint.can someone help me figure out if the unit is not working ,or if the setting are wrong.I call humming bird them self they walked me through the setting and it still doing it. I even returned the unit for a new one,but no luck it still doing the same thing.has this happen to any one else out there.if so can you help me. ps I have used gps on the water for years so I do know how the find a fishing spot.I just cant figure out this one
Offline strawdg
Re: gps operation
« Reply #1 on: January 13, 2013, 06:58:34 PM »
Don't know if your unit has it but check http://forums.sideimagingsoft.com/index.php?topic=3964.0 out and see if this helps.... :D
Actually it may be better to search the forums for 'arrival alarm' as the link actually is about setting arrival alarm distance to a specific waypoint.... not waypoints in general
Straw
« Last Edit: January 13, 2013, 07:03:52 PM by strawdg »
Re: gps operation
« Reply #2 on: January 14, 2013, 09:07:25 AM »
with internal antenna you may not get much closer. It all depends on how many satelites you are capable of talking with and the quality of the signal. Is your site to the sky obstructed in any way.
Re: gps operation
« Reply #3 on: January 14, 2013, 12:57:27 PM »
Next time out on the water, make a Screen Snapshot of what the GPS Diagnostic View looks like whenever you have problems getting to a waypoint.
Offline tschultz
Re: gps operation
« Reply #4 on: January 14, 2013, 08:25:43 PM »
Are you talking about using the goto function of the unit?  If so zoom in???...
Where is the unit mounted?
Last post December 17, 2009, 12:00:40 PM
Last post October 08, 2012, 02:14:12 PM
Last post May 31, 2013, 03:44:20 PM
Last post September 08, 2015, 05:07:42 PM
by Mark Saikaley
