Author Topic: Alarm arrival option for waypoint  (Read 8058 times)
Offline cfleague
  • Unit(s): 898c
  • Software: 6.18
« on: April 22, 2012, 06:33:55 PM »
When you set the "Arrival" option on a waypoint to 25 feet, how can you designate it to
specific waypoint and not all of them or is that not an option?
Re: Alarm arrival option for waypoint
« Reply #1 on: April 22, 2012, 06:36:29 PM »
Right off hand I think you have to specify "navigate to" option and that will be a specific waypoint or route.
I will look thru the manual..
« Last Edit: April 22, 2012, 06:41:56 PM by sonar2000 »
Offline cfleague
  • Unit(s): 898c
  • Software: 6.18
« Reply #2 on: April 22, 2012, 08:58:13 PM »
What I want to do is use the alarm feature for a couple of shallow rocks that I have marked with  way points.  I want the alarm
to sound off when I get within 25 so I don't hit them.
« Reply #3 on: April 23, 2012, 09:00:28 AM »
Now you are asking a good question. I dont right off hand know how to set an alarm that will always be on for a particular target.
In the mean time I would put an icon on the rocks so you will see that you are approaching..
« Reply #4 on: April 23, 2012, 10:33:06 AM »
The Arrival Alarm was designed to be used to notify you when you get within XX feet of a waypoint.  If you want to use a waypoint to designate an obstruction than that is your right to do so however this will only work with one waypoint at a time and you will have to set the unit to “GOTO” or travel to that waypoint.  I do not believe that it will work in the manner in which you want.  What you are looking for would be a new feature.
« Reply #5 on: April 23, 2012, 10:38:00 AM »
CF, I check thru several of the HB manuals and dont see a way to associate a particular point  with an alarm.
It seems the feature is to alert you to a select goto or navigate a route function and let you know when you are approaching a turn or progress point.
It is a different alarm than "drift" or off course settings.
I think it is a good idea and you might want to submit it via the wish list on this forum.
http://forums.sideimagingsoft.com/index.php?topic=323.0
Last post June 09, 2009, 07:22:53 AM
Last post August 30, 2010, 10:45:57 AM
by robert diver
Last post December 23, 2010, 06:31:22 PM
Last post April 05, 2011, 02:49:32 PM
by 1kickerfish
Last post March 20, 2013, 05:57:52 PM
Last post June 01, 2014, 10:11:25 AM
by terryreid
Last post May 25, 2014, 11:30:28 AM
by snowman48047
Last post April 16, 2015, 08:59:28 AM
