Author Topic: Where to mount trolling motor transducer?  (Read 13795 times)
Offline spes
« on: January 08, 2013, 11:03:08 PM »
Hello,
If I want to mount an XTM 9 SI 180 T on my TM
the manual for it says to mount it forward of the motor shaft.
Will it still work if you can't mount it forward of the motor shaft?
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: Where to mount trolling motor transducer?
« Reply #1 on: January 09, 2013, 01:33:37 AM »
Yes, it will still work. Which sonar unit do you have? the 89X, 99X, and 119X should be the HDSI transducer. If you have a 798SI or 598SI, then that transducer is the right one.
Offline spes
« Reply #2 on: January 09, 2013, 05:51:06 PM »
I am going to be purchasing a 798 very soon.
(Going to a boat show in a few weeks, and crossing my fingers to find a good deal)
  I plan on returning the boxed transducer to swap for an HDSI for the transom and plan on purchasing an XTM 9 SI 180 T for the TM.
« Reply #3 on: January 10, 2013, 08:26:17 AM »
Uhhh…, you had better do some measuring than.  The XTM-9-HDSi-180-T is the same as the transom mount version HDSi transducer except that it comes with a trolling motor adapter in place of transom mounting hardware (many fishermen prefer using the Transducer Shield & Saver adapter as it helps protect the transducer).  It is the same length as the transom mounted HDSi transducer (6 inches long).
Offline spes
« Reply #4 on: January 10, 2013, 05:56:25 PM »
Thank you Greg,,
I measured the space on my TM and JUST make it
I'm guessing an XTM 9 SI 180 T would be slightly shorter?
Do folks who do run two transducers.. transom and TM,, do they run HD on both or just one?
« Reply #5 on: January 11, 2013, 11:21:25 AM »
Yes the XTM-9-Si-180-T is shorter (almost 4 inches).
I would guess that those who run the HDSi transducer at the transom also run the HDSi at the bow.  You have to for the 800kHz Si sonar to work well.
« Reply #6 on: January 11, 2013, 02:05:03 PM »
If you have one display unit and you switch transducers it will be fine.  However if you plan on expanding to two units then only have one on at a time for sonar. These transducers can interfere with each other..
Offline spes
« Reply #7 on: January 11, 2013, 05:12:44 PM »
Thanks for the replies.
I havn't bought my unit yet. But I will be getting a 798 before the season starts.
  The 798 doesn't have 800khz,, but from what I have read here the HDSI transducer will still give a sharper image.
Please correct me if I'm wrong on that one. Couple hundred difference two go that route.
« Reply #8 on: January 11, 2013, 05:33:06 PM »
Not sure how many actually use the 800. I would think that most are using the 455.
« Reply #9 on: January 14, 2013, 01:12:34 PM »
You are correct spes.
Last post July 05, 2010, 02:34:14 PM
by Wayne P.
Last post January 02, 2012, 07:40:33 AM
by tommy29461
Last post February 21, 2012, 11:42:08 PM
by Will
Last post March 21, 2014, 05:05:53 PM
by Cookiecutter2
Last post May 02, 2014, 09:43:29 PM
by captainbrad
Last post October 06, 2016, 09:03:12 PM
Last post April 11, 2017, 07:52:15 AM
by Whistler
Last post November 16, 2020, 06:53:29 AM
by danlaboucane
