Author Topic: AS 360 SSI transom mount convert to DIY trolling motor mount  (Read 8712 times)
Offline ALHK
  • Unit(s): 1199ciHD Helix10Gen1
« on: November 15, 2020, 06:45:13 PM »
Can AS 360 SSI transom mount unit convert to DIY trolling motor mount or fixed simple pole at the bow? I mean ditch the extend-retract system and use remaining transducer pole only. Is it doable? Thanks in advance.
Re: AS 360 SSI transom mount convert to DIY trolling motor mount
« Reply #1 on: November 15, 2020, 08:40:36 PM »
Starting at page 48 shows how to remove the pod  ...
https://humminbird.johnsonoutdoors.com/sites/johnsonoutdoors-store/files/assets/misc/HU/H/HUM_productmanual_IG_AS360SI_532050E/HUM_productmanual_IG_AS360SI_532050E.pdf?_ga=2.96148820.959744782.1605490429-1564748650.1605315958
Possible to convert to a pole mount - probably
Feasible to convert to a pole mount - not sure
Keep us informed if you try this idea  ...
Offline danlaboucane
  • Unit(s): ,798 hd onix8 ct , solix 12 msi
  • Software: 7.6 ,3.03
  • Accessories: sm3000+eth 5 port to get SI on onix CT,
« Reply #2 on: November 16, 2020, 06:53:29 AM »
if someone was to give one to me i would do it !
i will install a pole style transducer holder at bow at some point all the while with a 360 of some kind as the main ducer .
i have an old jonhson troll motor braket that should be a good pole holder .
Last post July 05, 2010, 02:34:14 PM
by Wayne P.
Last post January 02, 2012, 07:40:33 AM
by tommy29461
Last post February 21, 2012, 11:42:08 PM
by Will
Last post January 14, 2013, 01:12:34 PM
Last post March 21, 2014, 05:05:53 PM
by Cookiecutter2
Last post May 02, 2014, 09:43:29 PM
by captainbrad
Last post October 06, 2016, 09:03:12 PM
Last post April 11, 2017, 07:52:15 AM
by Whistler
