Author Topic: 596c HD DI with ice transducer  (Read 19209 times)
Offline bright
« on: January 04, 2013, 09:20:30 PM »
Had to replace 798ci HD SI unit as it got stolen and decided to get 596c HD DI. Since I already had ice transducer and it worked fine on 798 I just tried to get it hooked up and got an error message saying  "transducer not connected". As far as i remember I had to change sonar type to Universal sonar on 798 to get it working properly, but I could not see this option on 596. Can't seem to find anything in the manual except the fact that ice transducer is indeed an optional accessory.  any help would be appreciated..
Re: 596c HD DI with ice transducer
« Reply #1 on: January 09, 2013, 02:33:22 PM »
That manual was written for both DI model and non-DI model units.  The ice transducer was meant for the non-DI units.  I hope you didn’t do it but trying to use the Ice transducer alone with your 596c HD DI unit could cause internal damage to the DI circuitry within the unit.  Of course the unit has to be transmitting to do this (running in the normal operating mode) and if all you got was the “Transducer Not Connected” message it never got to that point.
Your best bet (in my opinion…) is to just use the DI transducer on some sort of rig for ice fishing.  It has 2D sonar and you will have your selection of a narrower or wider 2D sonar to use versus the 200kHz sonar that you would have gotten if you could use an ice transducer.
Offline bright
« Reply #2 on: January 09, 2013, 07:26:48 PM »
Greg,
Wow! That was indeed an unexpected response. As a customer, I find a fact that connecting transducer, clearly listed as compatible in the manual that is shipped with the unit, could in fact damage it, very alarming.
« Reply #3 on: January 10, 2013, 06:09:57 PM »
Bright, I agree, if in fact this is true then the manual needs revision and a warning sent to all who purchased.
I for one would be unhappy if following directions fried my unit.
Offline navionic
« Reply #4 on: January 11, 2013, 05:06:49 PM »
We mean the transducer XI 9 20 ?
http://store.humminbird.com/products/314001/XI_9_20
The model  596 HD  DI does not support it. The manual  are often errors. Check through the site. More accurate information.
« Last Edit: January 11, 2013, 05:08:56 PM by navionic »
Offline bright
« Reply #5 on: January 12, 2013, 02:48:35 PM »
both transducers actually work fine with this unit. the only thing required to have it XI 9/20 hooked up is to manually select normal mode of operation during initial startup.  "transducer not connected" message I was getting is actually related to the fact that XI 9/20 does not have a temp sensor, which seems to somehow talk back to the unit during initialization. as for compatibility chart on the web page, I wouldn't rely on it as 798 SI, which I was using with this transducer for well over 3 years is not even listed there.
Offline navionic
« Reply #6 on: January 12, 2013, 03:09:25 PM »
The temperature sensor is not to blame. Frequency transducer and 596c HD DI winter coincide only at the frequency of 200 kHz. So you think it's working. But on the 798 SI model, these frequencies are the same (200 kHz and 83 kHz)
So no problems with the work. The site is actually a bug that no model 798 for that transducer.
Offline bright
« Reply #7 on: January 12, 2013, 10:31:16 PM »
I guess you might have a point. Is there a real difference between this and non HD units hardware wise? I wonder if downgrading firmware (for non HD) would allow me to use both frequencies (83/200).
Offline navionic
« Reply #8 on: January 13, 2013, 07:03:22 AM »
The modified firmware does not exist. Moreover it is not recommended to reflash the device another firmware. Fraught with failure of the unit.
Offline bright
« Reply #9 on: January 13, 2013, 01:07:42 PM »
 Понятно что не рекомендуется. железо то одинаковое или нет?
Offline navionic
« Reply #10 on: January 13, 2013, 02:01:30 PM »
Possible. I advise you to quit the idea of ​​modifying the unit. I have not seen good examples.
« Reply #11 on: January 13, 2013, 02:37:14 PM »
Is this the right translation?
It is clear that it is not recommended. iron is the same or not
Offline bright
« Reply #12 on: January 13, 2013, 04:56:08 PM »
Got it, thanks.
Apologies, Chuck. Was just trying to clarify an answer to the question I posted earlier.
« Reply #13 on: January 13, 2013, 05:15:20 PM »
No problem, we have translators to help with posts.
You are ok.
Last post February 08, 2011, 02:53:29 PM
Last post January 12, 2012, 11:05:32 AM
by alex_under
Last post August 22, 2012, 01:02:24 AM
by Roddy
Last post December 26, 2012, 10:16:08 AM
Last post February 06, 2013, 12:02:44 PM
by jimmythegreek
Last post April 02, 2020, 09:40:21 AM
Last post June 17, 2014, 08:44:31 PM
by sblatt
Last post September 09, 2014, 10:33:01 AM
