Author Topic: 596c hd ci not reading correct depth  (Read 9966 times)
Offline sealine
  • Unit(s): 596c hd di
« on: August 19, 2012, 09:41:28 AM »
Hi My unit does not show the correct depth, always gives a max or 1100ft? and bounces around that sort of depth.
I have purchased a new ducer XNT 9 20 T and still get the same results, tried setting factory re-set but still the same.
Anyone have or had this problem?
thanks
Re: 596c hd ci not reading correct depth
« Reply #1 on: August 21, 2012, 01:19:57 PM »
Are you running another sonar unit at the same time?
Does this happen with everything else on the boat turned off?
Make sure that the bottom of the transducer is pointing downwards into the water when you test it.
If the new transducer does not help and nothing on the boat is affecting the unit, than it sounds like your 596c HD unit is bad and will need to be returned for servicing.
Offline Roddy
  • Scan,scan and rescan
« Reply #2 on: August 22, 2012, 01:02:24 AM »
Sealine, If you can post a side pix of the transducer instal on the boat.
Roddy
Scan,Scan and Rescan Roddy
Last post June 26, 2010, 11:53:43 AM
by JeffA
Last post June 23, 2010, 09:24:55 PM
by reelman
Last post June 11, 2010, 08:42:41 PM
by majflyboy
Last post June 05, 2011, 09:20:09 PM
by bigbass
Last post June 04, 2012, 08:31:34 AM
by kucai
Last post April 16, 2014, 12:04:58 PM
Last post April 02, 2015, 04:23:35 PM
Last post June 27, 2023, 09:07:12 AM
by oschi
