Author Topic: 797 SI Problem, Need to restart.  (Read 8196 times)
Offline Eksnipan
  • Unit(s): Onix 10 SI 797c2 SI
  • Software: 4.770
  • Accessories: XPTH 9 HDSI 180 T Plastic Thru Hull
« on: September 15, 2012, 05:24:23 AM »
Hi
When fishing in rough water my transducer sometimes latches on 0 meter depth  ? I think my sensor sometimes comes above water  ( or it can happen if crossing a vessels path )
then the depth goes from e.g 30-40 meters to 0 for 2-3 second and stays on 0m.
Sometime if shorter then a 1sec it comes back to correct depth.
But most of the time it latches on 0m and I have to restart the whole unit.
Is there a workaround (until I move the transducer )  To either a quicker "restet"  or filter out the 0-2m echoes so it doesnt lactch.
Have had the unit on two difffernt boats with  similar  problem.
BR Jan
Re: 797 SI Problem, Need to restart.
« Reply #1 on: September 17, 2012, 03:02:24 PM »
You could try updating the software but I don’t know how much that would help.
Try setting the Max Depth menu setting to a few feet or so deeper than the deepest water that you expect to be in.  Not much else you can do if the transducer is coming out of the water.
Last post July 25, 2009, 02:24:11 PM
Last post February 09, 2011, 02:04:08 PM
by terry0540
Last post May 12, 2011, 04:34:08 PM
Last post June 01, 2012, 12:16:49 PM
Last post March 27, 2012, 11:18:56 AM
Last post October 15, 2012, 04:28:12 PM
Last post August 25, 2014, 09:56:59 PM
by jimham82
Last post January 09, 2016, 06:28:20 AM
by skeeter08
