Author Topic: Problem  (Read 18192 times)
Offline cokeman6
Problem
« on: July 22, 2009, 07:40:18 PM »
Ok Here's my problem. Water depth readings are all over the place, especially the numbers after the decimal.
Depth readings were fine with my 797 that was mounted at the console. This year I purchase a 798 and mounted it at the console with a transom mount and moved the 797 to the front of the boat with a trolling motor mount. Both units have  the same issue with water depth.
I have tried running one unit at a time, turning off all other electronics, moving the unit from the console to the front of the boat, turning on and off the TVG and adjusting the filter. I also replaced the trolling motor transducer from the SI to the XNT 920 T.
Both units have the newest software.
Help…………..
Re: Problem
« Reply #1 on: July 23, 2009, 10:23:01 AM »
Cokeman6,
Try resetting everything to the factory defaults.
Than switch the Water Type to the Deep Salt water setting and decrease (use a higher number) the Surface Clutter setting.
Offline cokeman6
Re: Problem
« Reply #2 on: July 24, 2009, 11:21:40 PM »
Thanks, Greg. Made the changes today on the water and that fixed the problem. One more question, can I increase the size of my way point names so the a old blind guy (me) can read them going down the lake.
Re: Problem
« Reply #3 on: July 25, 2009, 02:24:11 PM »
That’s not possible Cokeman6.  You’ll have to use my optometrists’ solution and get bifocals like me!
Last post December 18, 2009, 03:24:41 AM
by IRC Kevin
Last post January 27, 2010, 01:04:26 PM
by RBROWN
Last post March 18, 2010, 07:19:56 PM
Last post August 29, 2012, 10:51:48 AM
Last post August 02, 2010, 01:36:53 PM
by cosmoz20
Last post September 04, 2010, 09:12:37 AM
by Kenosha
Last post November 30, 2010, 06:56:17 AM
by Trophycats
Last post February 09, 2011, 02:04:08 PM
by terry0540
