Author Topic: HUMMINBIRD 967 ISSUE  (Read 7685 times)
Offline paula 8519
  • Unit(s): 967, 1197, 858
  • Software: latest
  • Accessories: weather sense
« on: August 11, 2012, 05:13:15 AM »
I have a  Humminbird 967c which has developed an issue, the head unit is not recognising the transducer, a message appears on the screen at start up which reads transducer not connected, the unit  stays in simulation mode, it does this in air. I have a second 967 unit which does not do this, the unit recognises the transducer and goes into normal mode while the unit is in air. Any suggestions or is this a return to humminbird, any thoughts would be appreciated.
Offline Roddy
  • Scan,scan and rescan
Re: HUMMINBIRD 967 ISSUE
« Reply #1 on: August 11, 2012, 12:25:36 PM »
paula 8519, try exchanging ternsducers between the units.
If the second unit has the same issue replace the transducer, if not reapair the fist unit.
Roddy
Scan,Scan and Rescan Roddy
« Reply #2 on: August 16, 2012, 03:11:41 PM »
paula 8519, test the units with the transducer in water and not air.  There may be nothing wrong with either unit or transducer.  The 967 units cannot use the same transducer recognition that many other units use and so are less likely to correctly identify whether a transducer is connected while it is in air.
Last post January 02, 2010, 08:37:04 AM
by soretoe
Last post April 22, 2011, 06:18:03 PM
by Trytoofish
Last post February 07, 2012, 03:48:48 PM
by nicknight
Last post June 05, 2012, 08:39:53 AM
Last post September 17, 2013, 12:24:07 PM
Last post May 23, 2016, 04:36:16 PM
by Dave C.
Last post January 17, 2017, 08:10:07 AM
by TroyBoy30
Last post August 22, 2017, 08:02:58 PM
