Author Topic: 1197 Display  (Read 5692 times)
Offline smitty3501
  • Unit(s): 1197. 787, 797
  • Software: 6.4 ?
  • Accessories: interlink
1197 Display
« on: August 09, 2012, 07:55:22 PM »
Been having problems with the display on my 1197.  Took the unit to a buddies house, hooked it up  on his boat and display looks normal. I borrowed his spare transducer, came home, set it on the deck and hooked into splitter cable and still had the display problem. Disconnected the dual beam from the splitter and still had problem. Connected the side imaging transducetr ( buddies sitting on the deck) directly into the unit and problem went away.
So Im wondering if the problem could be with the splitter cable? I dont  have enough slack in the cable to plug my side-imaging transducer directly into the unit. Unfortunately its raining good right now so maybe this weekend I can try and get some more slack and validate. Does anyone think this is possible that the splitter cable could be creating some sort of interference, or seen this before?
Offline Roddy
  • Scan,scan and rescan
Re: 1197 Display
« Reply #1 on: August 09, 2012, 09:02:03 PM »
Check the pins on each end for corrosion or bent pins.
Roddy
Scan,Scan and Rescan Roddy
Re: 1197 Display
« Reply #2 on: August 10, 2012, 12:32:36 PM »
Is this Steve from the Yahoo Group?  If so, you need to test with the transducer in the water.
If this is not Steve than please further describe what you are meaning by a problem with the display on your 1197 unit.  Is the display faded, only partially showing, flickering,…?
Last post October 27, 2009, 02:45:33 PM
Last post March 14, 2010, 05:33:55 PM
by Chiboo
Last post May 18, 2011, 03:18:38 PM
Last post May 28, 2011, 05:56:07 PM
Last post April 09, 2012, 10:11:05 AM
Last post April 12, 2012, 05:56:34 PM
by Emma Clarke
Last post May 31, 2012, 08:59:52 PM
by rookiejd
Last post August 12, 2012, 09:37:42 AM
by SPLMAXSAM
