Author Topic: Adding an inexpensive 2nd display to a 898  (Read 16845 times)
Offline SPLMAXSAM
  • Angry Floater
  • Unit(s): 898c SI
  • Accessories: Weather Sense, Lake Master Chip, Ipilot
« on: August 09, 2012, 01:50:01 PM »
I have a small 16 foot center console boat.  I fish on a great lake for walleye.  I use a humminbird 898 mounted in the center console for navigation and sonar.
When trolling, I often face the stern to watch the rods and cannot see the 898 si display screen .  I am very frugal (cheap).  So i wanted a display mounted in the stern that would display sonar.  Network feature and a second humminbird was out of my budget
After several reviews, I realized the best way to add a 2nd display, would be to use the VIDEO OUT feature of the 898.
I ordered the video cable from my humminbird dealer.  I had a small 7" LCD screen used in automotive application.  It is 12 volt and is pretty bright display.  They can be found on ebay for @$40 - $99. The screen is not designed for marine.   I also had a 16 foot RCA cable and some red/black power wire.
I wired the power ground to the same power ground wire as my humminbird.  I plugged in the video out cable into the back of the Humminbird.  I routed the cables to the stern.  I connected my test display.
Here is a video showing a test run
http://youtu.be/o42osNnewlA
My next step is to paint the monitor housing light color (for heat) and to seal the housing for moisture
« Last Edit: August 09, 2012, 10:34:00 PM by SPLMAXSAM »
Re: Adding an inexpensive 2nd display to a 898
« Reply #1 on: August 09, 2012, 06:21:10 PM »
Your youtube link does not work.
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #2 on: August 09, 2012, 06:41:43 PM »
Offline SPLMAXSAM
  • Angry Floater
  • Unit(s): 898c SI
« Reply #3 on: August 09, 2012, 10:36:16 PM »
Sorry, I tried making the original post using my cell phone.  I was able to add some pictures and fix the link.
« Last Edit: August 11, 2012, 06:55:03 AM by SPLMAXSAM »
« Reply #4 on: August 10, 2012, 07:22:18 PM »
SPLMAXSAM, Looks like a great solution ..... Hope you can keep the water out.
I have experimented with this myself, but never have done a permanent mount.
Offline Roddy
  • Scan,scan and rescan
« Reply #5 on: August 11, 2012, 12:11:35 PM »
There are large number of 12VDC TV/Monitors on ebay at a chep price.
Roddy
Scan,Scan and Rescan Roddy
Offline SPLMAXSAM
  • Angry Floater
  • Unit(s): 898c SI
« Reply #6 on: August 12, 2012, 09:37:42 AM »
The video cable I used was VC1
Last post May 17, 2010, 04:27:24 PM
Last post March 09, 2011, 01:31:43 AM
Last post April 09, 2013, 09:04:30 PM
by Rough House
Last post July 04, 2013, 12:37:44 PM
Last post January 06, 2014, 08:00:24 PM
by Rotus623
Last post January 13, 2014, 12:49:10 AM
by slabbacks
Last post August 30, 2014, 06:58:48 AM
Last post March 14, 2016, 04:45:17 PM
