Author Topic: Temp Transducer Question  (Read 12605 times)
Offline offroad
  • Unit(s): 1197/ 898
« on: July 25, 2012, 04:15:11 PM »
Unit is a 1197  Tansducer is a XTM 9 SI 180 T  On the Trolling motor,  No temp reading is the problem,  Unit says no temp conected ,My question is... what transducer setting is required so l get a temp reading ?
Re: Temp Transducer Question
« Reply #1 on: July 25, 2012, 05:30:47 PM »
the message may be coming from a bad wire in the cable assembly. Check your connectors 1st..... 2nd make sure the sensor on the transducer has not been damaged..
Offline offroad
« Reply #2 on: July 25, 2012, 05:49:11 PM »
Thanks for that Chuck  but thats not the problem,, l have three of these transducers.  Brand new each one tells the same story,,, l have tried the diffrent transducers under that menu on the machine with no joy ,Also readouts display
« Reply #3 on: July 26, 2012, 09:12:49 AM »
Well, it now sounds like the unit itsself.  Not good.. Have you talked to customer service..
« Reply #4 on: July 26, 2012, 10:31:17 AM »
I don't know what software you are running, but
maybe if it's a newer version, there is a menu item
to say if you have an external temp probe or not.
Maybe check that.
Other than that, if it's happening on 3 separate transducers,
then I agree with Chuck, with it most likely being that your unit
is malfunctioning.
« Reply #5 on: July 26, 2012, 02:42:48 PM »
The temperature should show up regardless of the Transducer Select menu setting offroad.  Try going to the Accessory Test View and see whether it shows the Temperature as connected or not.
Try testing another Humminbird unit on at least one of the transducers to see if the temperature will readout or show as connected on them.  This does not have to be another 1197 unit and can be done with the boat on the trailer (unless you just need an excuse to go fishing…  ;D ).
« Reply #6 on: July 26, 2012, 03:01:46 PM »
Wow, are we looking at three bad transducers (new).
« Reply #7 on: July 26, 2012, 03:08:14 PM »
That is what we are trying to find out Chuck.  That is why I suggested connecting a different unit to at least one of the transducers.  Standard troubleshooting here: try and eliminate a component or section of a system to narrow down where the actual fault is.
« Reply #8 on: July 26, 2012, 03:09:27 PM »
He posted he had three doing the same thing..
« Reply #9 on: July 26, 2012, 03:20:28 PM »
Yes Chuck I read that.
That means one of two things:
#1 He purchased three new transducers that all have temperature sensor problems.
#2 His unit is not reading or making connection to the temperature sensor in the three new transducers.
To troubleshoot which of the above problems he has I suggested connecting another unit to at least one of the transducers.  This will confirm which of the above problems he has.
Offline offroad
« Reply #10 on: July 26, 2012, 04:18:31 PM »
Greg/ Chuck  l have the 898 as well and guess what ? the three Ducers do the same thing on it.... its saying not conected
 Why do l have three Ducers ?  They where cheap ! New in the box and they came from Amazon in the States and because l am not in the States it would cost too much to send them back, The photo that they advertised showed a Transducer like the Hd ones you get with your 1197  But when they arrived they where the XTM 9 SI 180T  Trolling motor ones  They work   but it looks like no temp....
« Reply #11 on: July 26, 2012, 04:48:28 PM »
The xtm 9 si has the temp probe. look on your transducers and see if there is a copper dot on the front.  That is the temp sensor.
Ok so now we have three transducers not working on two different units.
So with this information it now seems you bought three transducer that do not work with temp..
what is this world coming to.????
so the Amazon photo showed the normal si transducer but you got in the box the trolling motor transducers.
Could you tell if the ones you got had ever been opened. could the amazon seller have substituted three bad transducers for the trolling motor to you..
who on amazon did you get these from..???
chuck
Offline offroad
« Reply #12 on: July 26, 2012, 05:36:07 PM »
           on the box it says rapid response temp , Yes the Transducer has the temp silver dot on it  The boxes where sealed
     On my shipping instructions l did put l want the transducer that is pictured in the photo . The Company was Driven GPS.com  ,At the same time as the box arrived they sent a feedback form on a email , So l filled it in with the not so kind comments and sent them another email as well........No reply ..Yesterday l did contact HB  and explained the problem l thought in detail
This was there reply
 Thank you for contacting Humminbird. We appreciate your interest in our products.
Under the Set up menu tab scroll to the select read out option and select one of the boxes to temperature.
Offline Roddy
  • Scan,scan and rescan
« Reply #13 on: July 26, 2012, 11:54:32 PM »
Offroad, Join the BAD 180 T Club. I was sent from Humminbird both split open on the fwd edge joint.
I emailed HB CS no reply, called CS was told "That cant happen".
So I glued the xducers, it worked.
Roddy
Scan,Scan and Rescan Roddy
« Reply #14 on: July 27, 2012, 11:23:56 AM »
offroad, contact them back again.  They are just going through the same troubleshooting steps that you already went through.  Sounds like someone did not read your message very well.  If that does not help; forward me the messages and your contact information and I will forward it to a CRC Lead Person or Supervisor.
« Last Edit: July 31, 2012, 01:47:55 PM by Humminbird_Greg »
Last post March 25, 2010, 12:14:33 PM
by jclark
Last post June 10, 2011, 10:16:32 PM
by Roddy
Last post October 16, 2011, 10:56:58 PM
by Roddy
Last post May 01, 2012, 12:52:17 PM
by xSilmarilSx
Last post May 20, 2012, 11:22:34 PM
by GoldenDawn1
Last post May 30, 2012, 03:40:06 PM
Last post December 28, 2015, 02:15:57 PM
