Author Topic: 798 SI and 6.350 Update  (Read 14888 times)
Offline BryanB
  • Unit(s): 798CI SI
  • Software: 5.840
« on: June 26, 2012, 12:52:08 PM »
Has anyone tried updating the 798 SI  ( non HD version ) yet? I’ve updated mine last time without any problems, but the new 6.350 update isn’t recognized by my unit.
I’ve formatted my SD Card, done a Factory Default reset and nothing helps. I wouldn’t think they would offer it from my profile on the Humminbird site if it wasn’t compatible.
Any idea’s , thanks.
« Last Edit: June 26, 2012, 12:57:32 PM by BryanB »
Re: 798 SI and 6.350 Update
« Reply #1 on: June 26, 2012, 01:28:25 PM »
BryanB, do you have a 798c Si or a 798ci SI model (as your profile shows)?
The 6.350 software was released for the 798c Si model but not for the 798ci Si model.
Offline BryanB
  • Unit(s): 798CI SI
  • Software: 5.840
« Reply #2 on: June 26, 2012, 02:12:42 PM »
Yes I have the ci model. Strange how they showed an update on my profile that is not for my model. Thank you for clearing that up for me. Im running ver 5.840 now. Not sure if there is an update for my unit yet,  798 ci si.
Thanks for your responce
« Reply #3 on: June 26, 2012, 02:46:32 PM »
The 798ci Si models are running software version 6.300 right now.
I am e-mailing you a link through TransferBigFiles.com to download it from.
« Reply #4 on: June 26, 2012, 03:48:24 PM »
I am working on the 798 downloads. Give me a day or two to try and get the right loads in our download section.
« Reply #5 on: June 26, 2012, 04:20:43 PM »
You should have some help with this particular one in your e-mail Chuck.
« Reply #6 on: June 26, 2012, 08:20:59 PM »
Yep, I got your big file Greg.  Waiting on the file size transfer to be increased for me so I can get the larger files in the downloads.
I had it but I think the server took it down a step or two.
Robert is checking now..
Offline BryanB
  • Unit(s): 798CI SI
  • Software: 5.840
« Reply #7 on: June 26, 2012, 10:36:14 PM »
I'm up and running on 6.300 thanks to you guys, Ya have been more than helpful, thank you very much !
« Reply #8 on: June 27, 2012, 02:36:08 PM »
Haven’t been able to check on this myself but I was told that the correct file got placed on the Humminbird web site for the 798ci Si units.
« Reply #9 on: June 27, 2012, 06:54:06 PM »
should be good on this forum also.
Offline BryanB
  • Unit(s): 798CI SI
  • Software: 5.840
« Reply #10 on: June 29, 2012, 01:04:58 PM »
Guys is there anyway to downgrade software on these things ? Since going to the 6.300 it's became almost unusable for me. Using all the old settings no longer work for me, the unit is giving me tons of false signals now that I never got when running 5.840. It's like it way over sensitive now no matter how much I lower my sensitivity down, and also getting crazy SI readings where I never got them before :(
Hate to ask after ya helping to get this updated, but I'm kinda lost here.
And I see the humminbird site now shows 6.300 in there update section, it was 6.350. I guess that changed it over the last day or so.
If I can downgrade to 5.840 I'll be happy and just stick with it. Can someone post the 5.840 for the 798 ci si ?
Sorry about this guys, and thanks again for the past help.
UPDATE:
Nevermind ,
 I found an old copy of it on my computer and downgraded it back to 5.840.
I'll try it out later on the lake and see what happens
« Last Edit: June 29, 2012, 01:26:49 PM by BryanB »
« Reply #11 on: June 29, 2012, 05:17:22 PM »
BB, we several levels of software on the forum under downloads.
Just in case the guys have to go back a level or two due to new code issues.
Check it out.  downloads, then select you unit model..
« Reply #12 on: June 29, 2012, 06:37:41 PM »
Chuck...I looked for the 5.840 he was looking for under the 798ci SI..
5.450 is the latest one listed for his unit...
Maybe I was using misinformation...I'm not sure...
« Reply #13 on: June 29, 2012, 07:31:16 PM »
Rickie, you are probably correct.  The 798 series of units are a bit confusing to say the least. HB only put the latest software on their site so it is almost impossible to get from them earlier codes.
I usually rely on other members to ship me the codes (older) so I can puty them on the downloads.
Now I also find that I cannot upload files larger than 10meg to the site. I have sent Robert a message to reset my files size so I can get the larger ones downloaded.
Tell me again why I volunteered to keep the downloads up to date... ;D
HB could be a bit more helpful to us with code since they do not provide backlevel.
I will keep trying....
Offline BryanB
  • Unit(s): 798CI SI
  • Software: 5.840
« Reply #14 on: June 29, 2012, 10:52:24 PM »
I would be happy to send you 5.840 if you need it.
Offline ClemsonBloz
  • Unit(s): 798 si
« Reply #15 on: June 30, 2012, 07:33:54 AM »
Anyone know what enhancements are in the 6.30 update?
« Reply #16 on: June 30, 2012, 01:30:21 PM »
BryanB, yes please send it to me.
I will send you a PM with the address..
Offline BryanB
  • Unit(s): 798CI SI
  • Software: 5.840
« Reply #17 on: June 30, 2012, 02:03:37 PM »
Done
« Reply #18 on: June 30, 2012, 04:59:25 PM »
clemson, not sure of the exact or all inclusive update considerations.  I dont think HB releases all of the code information..
I remember a while back some document that describe the general release but cant seem to lay my hands on it.
I think one of the guys here may have posted it..
« Last Edit: July 02, 2012, 09:23:27 AM by sonar2000 »
Offline ClemsonBloz
  • Unit(s): 798 si
« Reply #19 on: July 01, 2012, 09:47:17 PM »
My unit has the 5.840 version I think.. Without any idea of enhancements that come in the new version,, I think I'll keep my current version unless there are some earth shattering updates..
« Reply #20 on: July 02, 2012, 03:50:29 PM »
You can go to the FAQ’s on the Humminbird web site and search for the software version (example: 6.300) and it will show you the changes made.
« Reply #21 on: July 02, 2012, 04:56:31 PM »
Does this show the complete change or just the highlites?
« Reply #22 on: July 03, 2012, 09:40:28 AM »
It lists those changes that we are told about.  Some things are explained well and some are not (my opinion).  Some have screen snapshots to help explain them but most do not.
« Reply #23 on: July 03, 2012, 01:58:39 PM »
OK, It would be nice to have an area that describe the fixes..but I guess we would have to pay for that also..
« Last Edit: July 04, 2012, 08:36:48 AM by sonar2000 »
Offline ClemsonBloz
  • Unit(s): 798 si
« Reply #24 on: July 03, 2012, 08:15:02 PM »
It adds a casting ring, and also removes auto sensitivity for the DI and SI..  It also changes some items with the chart portion..
I did the update on my non HD today and it worked just as well as before..
Offline Staafe
  • Unit(s): 798 HD + HDSI transducer
« Reply #25 on: July 06, 2012, 01:39:37 AM »
Why they remove this feature? "removes auto sensitivity for the DI and SI"
Last post January 14, 2010, 06:51:41 PM
Last post June 13, 2010, 09:03:58 PM
Last post July 16, 2010, 02:25:39 AM
Last post January 28, 2011, 11:27:12 PM
by Spnb8
Last post February 09, 2011, 04:23:44 PM
Last post March 08, 2012, 06:29:06 AM
by alnash
