Author Topic: 798 update code  (Read 9181 times)
798 update code
« on: June 22, 2012, 08:30:11 AM »
OK, folks, there are two threads that I hijacked so I am starting this one to hopefully get the other two back on track.
Allright then:
concerening update releases I am trying to sort out the following.
4486e139e5e849d4bdbd36a0bec8e9b0.bin   Is this the release for the international model or the USA model. And is it in fact 6.350?
Before I get our downloads mixed up I need to get this straight.
Any help will be certainly appreciated. As Greg said before there are so many units and code to keep up with. but we will try so you guys can have the latest..
HB could help if they would stop the long name and get back to the unit and release as in past..
« Last Edit: June 22, 2012, 08:32:25 AM by sonar2000 »
Offline wolfs4evr
Re: 798 update code
« Reply #1 on: June 22, 2012, 10:16:51 AM »
9dc04a28c99244da89442c81167e81b4.bin is the US 6.250 for the 798CI HD SI.  If that helps at all.
6d244b9892154170b6ce162f420f2459.bin is the US 5.840 for the 798CI HD SI.  If that helps at all.
« Last Edit: June 22, 2012, 10:18:33 AM by wolfs4evr »
Re: 798 update code
« Reply #2 on: June 22, 2012, 10:21:33 AM »
That definately helps me get my excel reference in order. I use that to keep track of the download section.
Thanks so very much..
Offline Shooter00
  • Unit(s): 798c SI 788ci HD
Re: 798 update code
« Reply #3 on: June 23, 2012, 10:17:46 PM »
This is the code that I received earlier this week for my 798c SI legacy.....
798c_v6_350_f0fe758dcce3488fbd87ec1f4cb689a1.bin
Re: 798 update code
« Reply #4 on: June 24, 2012, 04:30:58 PM »
Well maybe Hb is getting the idea.  At least with that code you can tell a unit and level.  Now what is all that long length of charac mean.  Nothing to me..
thanks Shooter.  I wil have to get back on the update trail for the downloads..
Did you update your unit and if so were or are there any issues.
« Last Edit: June 24, 2012, 04:32:58 PM by sonar2000 »
Offline Shooter00
Re: 798 update code
« Reply #5 on: June 24, 2012, 04:41:50 PM »
I havn't had any so far Chuck,
Everything went smooth______________ ;)
Re: 798 update code
« Reply #6 on: June 24, 2012, 04:52:34 PM »
Thanks, I guess it is time to update the downloads.  I need a software change first to allow me to get some larger files downloaded.
Last post April 02, 2009, 06:52:38 AM
Last post March 28, 2012, 06:29:35 PM
Last post April 22, 2012, 06:32:33 PM
Last post May 31, 2012, 10:18:51 AM
Last post October 04, 2012, 12:38:55 PM
Last post April 07, 2016, 12:04:06 AM
