Author Topic: 788 ci hd error code  (Read 9295 times)
Offline teeiron
  • Unit(s): 898 788
« on: March 28, 2012, 10:14:50 AM »
 about 5 minutes after startup of my 788ci hd di unit i get an  alarm sound and a message dhcp error.  hitting exit removes it from screen but is something wrong.
Re: 788 ci hd error code
« Reply #1 on: March 28, 2012, 11:17:09 AM »
Maybe.
You should double-check your battery.
Load test it.  Your voltage may be dropping.
Also, re-check all of your connections.
Try to take out all your cards and reboot and see if it happens again.
Go through the process of elimination.
« Last Edit: March 28, 2012, 11:18:55 AM by ITGEEK »
« Reply #2 on: March 28, 2012, 11:26:51 AM »
Do you have any reference to a dhcp error?  What the heck is that?
Offline lcookie
  • Unit(s): 998SI/1198SI/788DI/587DI
  • Software: 6.68/6.64/6.64/6.09
  • Accessories: Ethernet, GRHA, ASGPSHS,WeatherSense
« Reply #3 on: March 28, 2012, 05:47:12 PM »
The Dynamic Host Configuration Protocol (DHCP) is a network configuration protocol for hosts on Internet Protocol (IP) networks.
Do you have ethernet hooked up?  If so check cables.
« Reply #4 on: March 28, 2012, 06:29:35 PM »
lcookie..thanks for that information..
I would guess some type of ethernet program error here..
It wont be long before the user will have to call customer suport to get the unit turned on and off. :D
Last post April 02, 2009, 06:52:38 AM
Last post April 22, 2012, 06:32:33 PM
Last post May 31, 2012, 10:18:51 AM
Last post June 24, 2012, 04:52:34 PM
Last post September 10, 2012, 08:52:40 AM
by gros21
Last post October 04, 2012, 12:38:55 PM
Last post December 11, 2012, 02:33:03 PM
Last post April 07, 2016, 12:04:06 AM
