Author Topic: Need 997c SI protective cover for trailering  (Read 15468 times)
Offline firetiger
« on: June 18, 2012, 10:47:10 PM »
Need 997c SI protective cover for trailering.
Any suggestions? prefer commercial product, just don't have time for diy
TIA
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: Need 997c SI protective cover for trailering
« Reply #1 on: June 18, 2012, 10:59:57 PM »
You can get the hard cover from Humminbird. Product number UC 5
Offline George
  • Software: Always up todate
« Reply #2 on: June 19, 2012, 07:04:27 AM »
I remember reading that a few of the folks had to strap the cover on because they would blow off.
My units are on Ram mounts so I transport the units in my truck.  Also I like the protection of having them in the truck.
« Reply #3 on: June 19, 2012, 07:43:18 AM »
Yep, George, the covers will come off if not strapped on.  We use a large fat rubber band.
You could use a velcro band also.
chuck
Offline terry0540
  • Unit(s): 798ci SI NVB
  • Software: 4.780
  • Accessories: none
« Reply #4 on: June 19, 2012, 09:39:11 AM »
My wife made a bag to drop over my 798 that keeps everything together
Offline firetiger
« Reply #5 on: June 19, 2012, 11:01:59 PM »
Tks for comments. Ordered uc5 from amazon -$25.
Offline LocDown
    • Fishing Videos
« Reply #6 on: June 20, 2012, 12:11:49 AM »
My 997 is behind my center console windshield so the wind isn't as bad a factor as out in the open. I do have one of those big red twisty tie things I got from northern tool to help keep the cover on just in case.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #7 on: June 20, 2012, 12:20:18 AM »
firetiger
     I'm with George; all electronics ride in the truck. Printed circuit boards and vibration are not friends.
     Upside- More security and less vibration.   Downside- Plugging and unplugging the wire harness increases chance for problems.
terry0540
      Tell your wife "nice work" on the cover.
« Reply #8 on: June 20, 2012, 09:03:10 AM »
Previous posts before have shown the HB connectors  to be be of less quality than some others. What seems to be the big issue is the loss of contact of the pins. Certainly plugging and unplugging has a wear and tension effect on the pins.
But security and vibration are also concerns.
If you remove take a little extra care and dont be rough.
« Last Edit: June 20, 2012, 06:26:52 PM by sonar2000 »
Offline George
« Reply #9 on: June 20, 2012, 01:53:06 PM »
I have been connecting and reconnecting since 2009 without any problems.  I have always transported my HB units in the truck and have never given any thought to issues with the connectors.  Hopefully I am not just lucky but it good quality pins.
I do think that some folks are a little rough in the plugging and unplugging, but with the block connection system do not see how we can screw it up.
« Reply #10 on: June 20, 2012, 06:31:09 PM »
George....I think you are pretty carefull with your units and as so will have a better time with contacts.
Other who rush the disconnect a bit will experience some of the loss of contact.
And also the male pin and the female receiver are not quite matched in size. This is a consideration when the female connector expands slightly over time and does not make good contact with the male pin. Which is why the slight bending of the male pin will most times fixes for a while the mismatch.
We do a lot of connect and disconnect and have contact problems from time to time.
Since our 1197 is out of warrenty we plan on replacing all HB connectors with the good type., including the one in the unit..
« Last Edit: July 11, 2012, 06:16:54 PM by sonar2000 »
Offline Gattlin
  • Walking the shores of Galillee
  • Zebco 202 Musky hunters club:P
  • Unit(s): 898C SI & 858C Combo
  • Accessories: Lakemaster chips, Ethernet
« Reply #11 on: July 11, 2012, 05:32:43 PM »
And also the male pin and the female receiver are not quite matched in size. this is a consideration when the female connector expands slightly over time and doe not make good contat with the male pin. Which is why the slight bending of the male pin will most times fix for a while the mismatch.
We do a lot of connect and sisconnect and have contact problems from time to time.
 What is the good type? Part #?  :)
Just one last cast.
« Reply #12 on: July 11, 2012, 06:20:16 PM »
Several on the market and available usgin a google search for connectors.
However you can look at Lowrance and Garmin for a start and see a better connector for units that cost close to the HB price.
Of course in the higher range of units the connectors are much better but still of an affordable price and similar to the other manufactures.
Roddy has done a bit of looking and has links to the connectors. See if he will jump in here and post..
Last post May 07, 2012, 06:04:28 PM
by depark1
Last post January 05, 2013, 03:56:14 PM
by Patty
Last post August 22, 2014, 12:14:58 PM
by waggman
Last post May 18, 2015, 10:58:06 PM
Last post August 20, 2015, 11:09:13 PM
Last post January 01, 2016, 08:30:25 PM
by buell1965
Last post April 01, 2016, 12:02:13 AM
Last post August 03, 2023, 02:39:15 PM
by Papa D
