Author Topic: new to the forum  (Read 6359 times)
Offline nodoubledigityet
  • Unit(s): 997 c si
new to the forum
« on: June 17, 2012, 05:53:47 PM »
I have a ? I recently purchased a 997 c si and tried it yesterday for the 1ts time . the 1st 2 mins it worked great then all of a sudden the right side of the image went out ,i checked the settings and all is good nothing blocking the right side ,black screen on the right ,unplugged and plugged the transducer same thing , put it in demo mode and both sides work ,...any idea of whats wrong / I think I might have a defective transducer
Re: new to the forum
« Reply #1 on: June 17, 2012, 06:05:47 PM »
Could be a defective transducer.
Is this 997 a new out of the box or a used unit?
Where did you get it?.
The 997 is a legacy product meaning it may have very limited support.
What is the code level installed in the unit?
You can search this forum for additional information of black screens for a particular SI side and other related search arguments.
  • Unit(s): 997 c si
« Reply #2 on: June 17, 2012, 06:12:32 PM »
it is preowned everything else works perfectly ,all updates are done
« Reply #3 on: June 17, 2012, 08:32:55 PM »
It could be the transducer, or it could be the connection.... Read this forum for some tips   http://forums.sideimagingsoft.com/index.php?topic=4086.msg25772;topicseen#new
« Reply #4 on: June 18, 2012, 02:57:11 PM »
If you know of someone else that is running a Humminbird Side Imaging unit (any model will do) you can test your 997 unit on their transducer to see if the right Si sonar works or not.  You can also check the map on this web site to see if some living near you is a member and would be willing to test your unit.  Otherwise you can make a guess that it is the transducer and buy another one to try or you can send your unit into Humminbird to be serviced.
Last post October 22, 2011, 04:29:52 AM
by pebe
Last post September 27, 2013, 10:14:19 AM
by Clackerbuzz
Last post December 17, 2013, 04:35:19 AM
by pebe
Last post January 18, 2014, 12:39:02 PM
by 5eyes
Last post February 11, 2014, 08:13:14 PM
by freezerfiller
Last post November 15, 2015, 07:22:45 AM
by N9Phil
Last post January 02, 2016, 11:37:20 AM
by ezgo
Last post February 07, 2019, 04:34:22 PM
