Author Topic: 997 GPS issue on Gville Lake  (Read 4163 times)
Offline jdlandrum2002
  • Unit(s): 997 si
« on: June 12, 2012, 04:19:14 PM »
I have a 997 with just the factory base maps..... When I go back into some creeks on Gville for instance North Sauty the lake map just disappears and it just shows land where there should be water.   Its basically cutting a good portion of the creeks out.  From about mid creek back its just not there.  Anybody else had this issue???
Re: 997 GPS issue on Gville Lake
« Reply #1 on: June 14, 2012, 12:22:20 PM »
That is the limit to the map data that we bought and installed in the 997 units.
Only way to see more map data up the creeks would be to buy a Navionics or LakeMaster mapping card that has this data – I do not know if either do, so check on this before buying a mapping card.
  • Unit(s): 997 si
« Reply #2 on: June 14, 2012, 08:35:38 PM »
Thank you for the reply.......  The image of the backs of these creeks actually show up sometime, then if i zoom out or in the creek disappears and it will just randomly re-appear everyonce in awhile.   I never have this problem when i'm on the main lake....it always occurs when i get back into a creek.  I will be buying a navionics chip very soon so i wont have the problem anymore, I've just always wondered why it does it.  Thanks again Greg
« Reply #3 on: June 14, 2012, 08:46:11 PM »
I think that I might like to see a map run on my unit before I would purchase one. It may work or it may not.  Ask a store for a demo if you can find one that will help you..Or another member who has the chip..
« Reply #4 on: June 15, 2012, 09:09:48 AM »
Sounds like the creek data may be on one map hex but not another.  You happen to be moving from one map hex area to another and this is why it shows up and disappears.
I would check to see that the creek data is on the map card you are buying.  Testing it out on your 997 unit (or having someone else look for you) is smart shopping.
Last post May 29, 2009, 08:48:36 AM
by Bad Habit
Last post January 02, 2010, 08:37:04 AM
by soretoe
Last post April 20, 2010, 05:01:24 PM
by calli1
Last post February 07, 2012, 03:48:48 PM
by nicknight
Last post April 26, 2012, 09:36:12 AM
Last post April 26, 2012, 11:39:50 AM
Last post March 28, 2014, 12:02:55 PM
by ezfishn
Last post December 17, 2014, 11:11:51 AM
