Author Topic: new to side imaging  (Read 27376 times)
Offline hoppies70
  • Unit(s): 798hd
new to side imaging
« on: June 05, 2012, 08:15:30 PM »
are this steps, just trying to learn to read unit
Offline JDyment
  • Unit(s): None
Re: new to side imaging
« Reply #1 on: June 05, 2012, 09:24:19 PM »
  kinda looks like a dock that got away and sunk?
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #2 on: June 05, 2012, 10:37:54 PM »
hoppies70
         It might be a dock that was knocked loose by the barge traffic.
         I'd tie up at shore and walk up that dirt road to the business/ plant at the top
         of the hill and look around. I think your answer is up there.
                     Mike
Offline Rüdiger
« Reply #3 on: June 06, 2012, 03:38:54 AM »
Hi Hoppies
What ever it is, definitely a good shot.
Congratulations and welcome to the Forum :D
mvh
Rüdiger
Finding is better than losing
« Reply #4 on: June 06, 2012, 08:49:02 AM »
As NK suggested take a walk and look.  It does look a bit like two drainage ditches or concrete pipes emptying into the lake..
« Last Edit: June 06, 2012, 06:53:14 PM by sonar2000 »
« Reply #5 on: June 06, 2012, 05:21:07 PM »
I'd try to shorten the range and get a bigger look at it.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #6 on: June 06, 2012, 11:52:20 PM »
hoppies70
       Funny how the mind works sometimes. We see a snapshot and think of a fixed body of water ( lake/reservoir).
       We are dealing with a river here, so the target could have come from miles and miles upstream.
       I like Bob B's idea of bringing the SI range in. Target is in 20 FOW, so maybe try 40' on SI. Target is close to shore, so locating it shouldn't be a problem.
       Also I would try SI from several different directions. ie N to S, S to N, E to W, W to E etc.
       One thing I don't understand is in the SI view, the left end on the item is directly under the boat. Why isn't there a better 2nd echo in 2D?
       I would expect to see a solid red second echo in those conditions.
               Mike
Offline hoppies70
  • Unit(s): 798hd
« Reply #7 on: June 07, 2012, 08:41:12 AM »
Thanks everyone for the input.mike you are correct it is a river pic. i plan on going this out wkend .  i will try an get some different views. will change  range on si, dont know why i didnt do that before. thanks again .  hoppies
« Reply #8 on: June 07, 2012, 09:38:22 AM »
Hoppies, sorry I was looking at the left side of the screen. I see the red dot now and what you are talking about. does look like a ramp to a dock  or dock. Great pictures...Let us see what you get this next time out..
Offline Carl
  • Unit(s): 798ci SI
  • Software: 4.620
« Reply #9 on: June 07, 2012, 07:48:55 PM »
Looks like you have some issues on the right side. Your water column looks hazy.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #10 on: June 08, 2012, 11:06:56 PM »
Carl
    I saw that also. Left water column is clear/ right is hazy, but right SI bottom images are good.
    No clue here on this. Will be interesting to hear if it stays this way.
            Mike
Offline Carl
  • Unit(s): 798ci SI
  • Software: 4.620
« Reply #11 on: June 09, 2012, 01:31:54 PM »
I had this same issue though not as bad. Was able to fix by adjusting contrast and sensitivity. However it still shows up slightly when I use humviewer.
by Wylezalek
Last post September 09, 2013, 01:28:56 PM
by prowler650
Last post October 26, 2015, 09:34:42 PM
Last post July 19, 2017, 12:27:05 AM
Last post May 30, 2018, 08:11:04 AM
