Author Topic: Care and Maintenance of your new Humminbird Unit Screen  (Read 16436 times)
« on: May 31, 2012, 04:44:09 PM »
Care and Maintenance Information
    Your Humminbird fishfinder is designed to provide years of trouble free operation with virtually no maintenance. Follow these simple procedures to ensure your Humminbird continues to deliver top performance.
    If the unit comes into contact with salt spray simply wipe the affected surfaces with a cloth dampened in fresh water. Do not use a chemical glass cleaner on the lens. Chemicals in the solution may cause cracking in the lens of the unit.
    When cleaning the LCD protective lens, we recommend that your first use a solution of warm mild soapy water (Dawn or similiar mild brand), wipe the face dry and if water spots remain, use a solution of water and vinegar such as Windex with vinegar.  Always use a soft cloth. Do not wipe while dirt or grease is on the lens. Be careful to avoid scratching the lens.
    Chemicals like sunscreen and bug spray can cause permenant damage to the protective lens.  This is not covered by warranty.
    If your boat remains in the water for long periods of time, algae and other marine growth can reduce the effectiveness of the transducer. Periodically clean the face of the transducer with liquid detergent. Pivoting the transducer up in the bracket may allow better access for inspection or cleaning.
    If your boat remains out of the water for a long period of time, it may take some time to wet the transducer when returned to the water. Small air bubbles can climb to the surface of the transducer  and interfere with proper operation. These bubbles dissipate with time, or you can wipe the face of  the transducer with your fingers after the transducer is in the water.
    NEVER leave the fishfinder in a closed car or trunk - the extremely high temperatures generated in hot weather can damage the electronics.
Thanks to erocks4u
« Last Edit: May 31, 2012, 04:53:11 PM by sonar2000 »
Last post March 29, 2009, 05:37:36 PM
Last post January 31, 2010, 03:36:02 AM
Last post February 12, 2010, 08:43:08 PM
Last post May 30, 2010, 02:57:38 PM
by vmoyers
Last post March 05, 2014, 09:48:32 PM
by Perch Jerker
Last post March 28, 2014, 03:48:45 PM
Last post February 05, 2016, 09:17:25 AM
Last post February 07, 2019, 04:34:22 PM
