Author Topic: New 998, old 798C SI, and Interlink?  (Read 8762 times)
Offline jimmybass2
  • Unit(s): Onix 10ciNT, 10ci SI NT, (2)8 ci CT
  • Software: 2.72
  • Accessories: 360bow,Navionics+, LakemasterSmartstrike
« on: May 23, 2012, 06:59:52 PM »
Simple question.  I want to move my 798C SI to the bow and add a new 998.  Will my Interlink work with the new 998 (instead of Ethernet) and what software updates should I run or not worry about?
Thanks in Advance,
JimmyBass
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: New 998, old 798C SI, and Interlink?
« Reply #1 on: May 23, 2012, 07:19:55 PM »
try to use the same version software on both units. If both are ethernet capable, why not use it? You can share sonars via ethernet plus everything else interlink can do.
Offline jimmybass2
  • Software: 2.72
« Reply #2 on: May 23, 2012, 07:23:00 PM »
LocDown, thanks for the reply.  The 798C SI is NOT the HD version, so no Ethernet on that one.  I'm going to use the InterLink for now, assuming that its not an issue.
JimmyBass
Offline LocDown
    • Fishing Videos
« Reply #3 on: May 23, 2012, 07:27:03 PM »
There's no guarantee that it will work correctly. You should update the 998 to the latest software. Hook up the interlink to the 998 and power up. Let the interlink update and then hook up the 798 and hope for the best.
Last post April 19, 2011, 08:38:12 AM
Last post September 20, 2011, 02:09:16 PM
Last post December 12, 2011, 02:36:56 PM
798c si
Started by dbrettle 798c SI
Last post February 06, 2013, 04:27:05 AM
by dbrettle
Last post November 15, 2013, 03:39:26 PM
by CamoHunter
Last post April 11, 2016, 10:50:14 PM
