Author Topic: Interference On 1198  (Read 7427 times)
Offline calli1
  • Unit(s): 1198 S I & 787c2i
« on: May 22, 2012, 03:01:47 PM »
Ok folks...I...like some have interference on my Humminbird 1198 when I hit my trolling motor power switch/button.    This only shows as it seems on my side and down image views.  Any suggestions ?  Please .....
Re: Interference On 1198
« Reply #1 on: May 22, 2012, 03:20:52 PM »
Start off with putting your sonar on a battery with nothing else hooked to it.
Then, make sure you route the sonar wires away from the trolling motor wires, and
your main engine wires.
If the wires have to contact each other, then place them at right angles like a cross.
Then go from there with other methods to reduce/eliminate interference.
« Last Edit: May 22, 2012, 03:22:58 PM by ITGEEK »
Offline Roddy
  • Scan,scan and rescan
« Reply #3 on: May 22, 2012, 10:53:14 PM »
Replace the cheep Hummingbird plugs!!!!!!
Scan,Scan and Rescan Roddy
Offline calli1
« Reply #4 on: May 22, 2012, 11:29:40 PM »
I think I have it taken care of now.  Reduced Sensitivity down to 8 to 10, noise settings to low from high 3 and a couple of other settings changed.  Just checking it out in my driveway...it doesn't show the interference on the screen now.  We shall see and if it continues to do so, I will run a groundwire from metal on trolling motor to Neg. Term. on Cranking battery.  Wish me luck and the connectors are good.
Last post January 12, 2010, 07:43:29 PM
by garyr
Last post April 24, 2011, 11:05:28 AM
by FlatsFokker
Last post June 27, 2011, 01:53:40 PM
Last post July 15, 2011, 09:15:58 PM
by Double Digit
Last post October 30, 2011, 08:53:59 AM
by Mark997
Last post December 11, 2012, 07:22:15 AM
Last post March 14, 2013, 04:37:52 PM
by Rickard
Last post April 16, 2013, 02:33:32 PM
